Laptop probs
edd_t
Am trying to sort out a users Laptop.
When booting normally it gets to the Windows XP screen, then goes blank! The hard disk is still being accessed but nothing happens.
I get the exact same thing when trying Last known good.
When booting in safe mode it starts to load drivers, gets as far as a atisgkaf.sys driver then stalls and sits there. This is obiously a graphics driver.
Anyone got any ideas?
Am thinking i could rename that ati driver and see if the machine will boot aftwards...
Could be chipset related driver (ati rs4x0 integrated chipset)
but.. I think you're right anyway. A quick google of atisgkaf returns people with the same problem as you!
I would boot with some kind of MiniPE recovery disk as Pete says, like Barts disk or ERD Commander, and try various things such as replacing that file with a copy of vga.sys or deleting (renaming) the file or even better just removing the whole entry for that peice of hardware in hklm\system\[whatever control set.. check them all]\enum\pci
If you don't have a miniPE disk, you can open the file \windows\system32\config\system in regedit from another XP machine. Just connect up the disk and open regedit, highlight HKLM, go to Load Hive and load the file system from that path, give it whatever name you like and make sure you unload it afterwards.
I hate shitty software problems. It seems that Sage are second only to Symantec.. and it's Act! 2006 here we're talking about, so it used to be Symantec anyway.
I've just never ever seen anything so pathetic. Nearly every single problem on their knowledgebase says "there are many things which can cause this.. try.. then try ... then try.." FFS. They just don't know do they. grrr.
Once again my hatred for ACT! and all things Symantec has been reassured by the 'simple' installation of a trial version for a customer.
