Harps Posted March 24, 2006 Share Posted March 24, 2006 I just got me a Supe! Black TT Aero, and its beautiful. Spent ages looking at it (and others) to make sure it was all good, and it certainly looked it. Had a great time driving it the 50 miles home (other than briefly losing the back end in the wet and seeing how dirty it got on a relatively short journey!). However, about 2 miles from home, the red '!' warning light came on. No other lights illuminate and theres no difference to the performance. If I switch the engine off, it clears it until I push the car again. I'm praying its something minor! I would be grinning like an idiot, but I'm a tad concerned! Link to comment Share on other sites More sharing options...
SupraHuman Posted March 24, 2006 Share Posted March 24, 2006 Hi and welcome,congrats on your new purchase,the warning light can be anything from a to z but i've heard that brake fluid level often get this light turned on,for safe measure you can swing past your local Mr.T and do a diagnostic check Link to comment Share on other sites More sharing options...
Ian R Posted March 24, 2006 Share Posted March 24, 2006 Before you do anything have a look at http://www.mkivsupra.net/vbb/showthread.php?t=39044&highlight=diagnostic+codes very usefull thread Ian C put together Link to comment Share on other sites More sharing options...
Tom S Posted March 24, 2006 Share Posted March 24, 2006 well done harps... Pics needed now though......... Link to comment Share on other sites More sharing options...
RedM Posted March 24, 2006 Share Posted March 24, 2006 If you can make the light go off again after pushing it and come back on when you push again I'd check the brake fluid level. Even if it's at the top you still might not have enough. Search for brake fluid level warning light and you'll see what I mean. Got any pics? Link to comment Share on other sites More sharing options...
Harps Posted March 24, 2006 Author Share Posted March 24, 2006 Cheers guys, I'll have a look-see. Was gonna get some pics tonight, but I'll clean it up tomorrow and post em. Glad to see its not likely to be serious! The grin's back Link to comment Share on other sites More sharing options...
Ian R Posted March 24, 2006 Share Posted March 24, 2006 Oops forgot to say Link to comment Share on other sites More sharing options...
Homer Posted March 24, 2006 Share Posted March 24, 2006 Well done mate The warning light isn't likely to be anything serious, low brake fluid or a fault active front spoiler are very common causes. Link to comment Share on other sites More sharing options...
Tom S Posted March 24, 2006 Share Posted March 24, 2006 I had the same problem, carry brake fluid in car as happens every few moths, fill up to top, works fine. Link to comment Share on other sites More sharing options...
JohnA Posted March 24, 2006 Share Posted March 24, 2006 Black TT aero. Wow. Post pics! Link to comment Share on other sites More sharing options...
kghelmet Posted March 24, 2006 Share Posted March 24, 2006 slam the bonnet down,mine has the same problem if i don`t slam it. black supra:) Link to comment Share on other sites More sharing options...
lockys96 Posted March 24, 2006 Share Posted March 24, 2006 its probably just the same mine was doing, when i went above 60-70mph the warning light came on and stayed on, turn engine off and it was fine. i previously had a active spoiler on the front of my car, and a aftermarket kit was fitted when i bought mine. go see if your warning light comes on when you reach 60-70mph, the active spoiler wants to come on, if its that, nothing to worry about, simply remove the spoiler ecu, lol welcome pics Link to comment Share on other sites More sharing options...
Ian R Posted March 24, 2006 Share Posted March 24, 2006 but it is not advised to turn you engine of at 70mph :) Link to comment Share on other sites More sharing options...
lockys96 Posted March 24, 2006 Share Posted March 24, 2006 anything to save fuel, coming off a motorway, just coast it in. Link to comment Share on other sites More sharing options...
Todd Posted March 24, 2006 Share Posted March 24, 2006 slam the bonnet down,mine has the same problem if i don`t slam it. black supra:) eeekk!!! be very careful, the metal is very soft on the bonnet and you could do a lot of damage if you keep slamming it down. Lower the bonnet down but don't close it, apply gentle pressure to one edge and you should hear a click from the latch, try the same on the other side (yup 2 latches) if like mine one of them wasn't catching and just needed the rubber stoppers adjusted Link to comment Share on other sites More sharing options...
terawua Posted March 24, 2006 Share Posted March 24, 2006 welcome - enjoy your car in the best colour 202. Make sure the brake fluid is above the MAX marker by about 1/4 of an inch or the warning light keeps coming on. Or check the oil - thats the other thing that makes mine go on every now and then. Link to comment Share on other sites More sharing options...
connor66 Posted March 24, 2006 Share Posted March 24, 2006 Welcome to the forum bud Link to comment Share on other sites More sharing options...
Nic Posted March 25, 2006 Share Posted March 25, 2006 Agree with others, likely culprits are either low brake fluid or active spoiler. The other common cause is a bad speedo conversion. If no other warning lights come on then it shouldn't be anything too serious. If it is low brake fluid the warning light will usually come on under braking or acceleration. The sensor for teh fluid is very sensitive so even if the fluid is only slightly under the level it will illuminate, try topping it up just above teh level. If it is the active spoiler, then the light will come on at a certain speed each time. Does your car have an after market front fitted and does it have an active spoiler button under the stereo? If yes try pressing the spoiler off button and then driving, the button will dissable the spoiler ecu, which shoudl mean the warning light no longer comes on. If it is neither of the above then do the diagnostic check explained in the link above. Link to comment Share on other sites More sharing options...
Harps Posted March 28, 2006 Author Share Posted March 28, 2006 A quick thanks for all the opinions guys. Went for a drive on Sunday, with the active spoiler off, and no warning light! So I'm guessing that is the culprit. Picking the car back up later today as its having its alarm fitted, if the weather stays good I'll get some pictures up later today. I wasn't intending to buy one just yet, however I know how rare TT Aero's are, and this one was just too good to miss. I had a mechanic look it over and it all seems good! Thanks again! Harpsy Link to comment Share on other sites More sharing options...
Harps Posted March 28, 2006 Author Share Posted March 28, 2006 Maybe not too good to miss. Just got the car back, had a little ride out and pushed it up to 65-70, and not only did the "!" warning light pop up, but the engine light on the right read-out. My first thought was that it might be something to do with just having the alarm fitted, as it didn't happen on Sunday when I drove it. Does that sound likely? Once again, re-starting the engine cleared it, and it wasn't till I accelerated to that speed again that the lights showed up. I think I'd better get someone to check it Link to comment Share on other sites More sharing options...
Fifty Posted March 28, 2006 Share Posted March 28, 2006 Hi Can you read the code - use search "reading error codes by Mawby" -it will tell you what caused the engine lite to come on and how to read it - code 42 anyone; probably all related to poor speed convertor. someone else more technically able will be along shortly Link to comment Share on other sites More sharing options...
Harps Posted March 29, 2006 Author Share Posted March 29, 2006 Cheers bud, I've done a load of searches on the site, and I'm 99% sure its a dodgy speed conversion. I'll check the error code tonight to make sure, but I'm getting the warning lights, the cruise control wont sit at the speed I tell it to, and the second turbo & gear changes could run a little smoother. If that is the case, I'll see if I can find somewhere local to do it. Thanks for your help (and those who replied to older threads about the same problem, I really *really* should learn to search first!) Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted March 29, 2006 Share Posted March 29, 2006 hi mate welcome locky had similar problem it is deffo your active spoiler ecu, it is located behind the stereo there is two boxes in silve one needs disconnected and bingo do a search to see which box it is i have written down somewere but cant find it at mo. Link to comment Share on other sites More sharing options...
Harps Posted March 29, 2006 Author Share Posted March 29, 2006 Cheers, I'll have a search around! I did switch off the active spoiler on Saturday thinking that could be the cause (well, I depressed the button anyway), would the lights still come on? Link to comment Share on other sites More sharing options...
npotts Posted March 29, 2006 Share Posted March 29, 2006 Hi Harps Welcome to the club mate.... From what you are describing I would say that this is a faulty speedo converter. Its exactly the same symptons I had on my car and once fitted with a new converter resolved the problem. If it was your spoiler, I think the problem could be checked by simply pulling the spoiler fuse out. That way, if you go for a drive and it still comes on, the warning is pointing to something else. Like I say though mate, the symptons suggest to me a faulty speedo converter.... Nick Link to comment Share on other sites More sharing options...
