Mega boost on J-Spec T's
Justin
This can't go on much longer. I'm hitting 1.55 bar (22.6psi) now.
The bizare thing is I fully de-catted last year with a Blitz zorst. I put in a CW restrictor plate last winter and thrashed it in cold air days to make sure I was maxing out at 17.5 psi with the plate. I got this sorted.
But now I'm hitting 22.6 psi. To me this must mean the exhaust flow is escaping before the restrictor plate. After inspecting the pipe for holes my only guess is that the area where the first CW downpipe joins the engine with the three bolts is not properly screwed in tight (not fitted by CW I hasten to add) One of the bolts is not screwed all the way down but I can't tighten it any further myself seems to be locked tight.
Also (rarely) when I sometimes go round a bend under boost I get an extra noise like when you blow the top of a bottle of beer.
Any other reasons why I might be boosting so high? I'm gonna focus on the coupling for now but if anyone knows any extra stuff let me know.
Cheers
J.
bet its fun though
mine goes up and down. put back in ttc mode again and it feels awesome with tc. was thinking of sticking my RING PEICE in
hope you get it sorted
have tou tried to make a new ring with a smaller hole to restrict it a bit more.
you could have a few different rings for summer and winter. just a thought. you got ok fueling
Take it to and exhaust centre and get them to heat the nuts up , take em off and replace with new , make sure they do all the way up or use a washer if you have to , DO NOT try to just keep tightening that nut or you WILL shear off the stud and then you really will be upset .
Dude:flame Dev
PS whats wrong with 1.5 bar ?????:sly:
Get an old towel, soak it in water and ram it up the tailpipe of the exhaust with the engine idling, using your (shod...) foot to hold it in. If the exhaust is leaking you'll certainly here it, if it isn't the engine will stall if you seal the pipe up tight with the towel.
Why is I seem to be able to fit my pipes without them blowing, using all three nuts, correctly tightened, yet other people seem to see it as a challenge for "Heath Robinson 2003" :innocent:
Funny this thread shuold come up, Im decated with CW ring, had it fitted at the beginning of the year, never hit past 1.1 all year so far until I checked my peak boost the other day, F4CK ME, it had hit 1.45, nearly 1.5 at some point, and booted it the other day and because it was night time saw the read light flash on as it hit 1.4 again. Is this just down to the cold weather setting in, seems a bit much though just for colder weather, 1.1 - 1.4. Whats the PSI on 1.1 ????
Yeah but my point Ash was that I fitted the ring in very cold weather last year to find out how big to have my ring (oowwwerr)
I got down to 17.5 psi and it stayed like that for a year until now.
Will try the towel trick. Chris is a genius ain't he :)
Ash,
I'm having similar problems. Leon fitted a restrictor ring in March and it kept it to ~1.1bar. Now I've fitted CW's SMIC and the cold weather is here, sometimes I'm hitting 1.4 :( Mostly its OK at 1.2.
