awesome rims
carl0s
:D
They're Volk GT-AV 18x9 up front and 18x10 rear, in Grey/Silver.
Black it is for the calipers then. Shoud I just sand them down with some rough glasspaper? Don't really want to have to send them away to be blasted.
Do a search mate. There are tons of threads on this. I used a wire brush to get all the surface corrosion off, then cleaned with brake cleaner and old rags. Mask everything off real well, prime, let dry, prime, clean, light coat, let dry, light coat, let dry, finishing shots, let dry, remove masking, reassemble, apply decals. Complete.
To clean the calipers use a good wire brush, if you if have one a mini drill is great for cleaning them up, I have done sets for friends and mine as well as mine, just get the caliper as clean as poss and take your time with the paint, mine had 3 coats of paint..!
Supra Brakes
Evo 4 Brakes
