TT-DEK Posted February 19, 2006 Author Share Posted February 19, 2006 THANKS for your info guys!!! Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 19, 2006 Share Posted February 19, 2006 Like water, colourless and transparent. Smells different though (lol) and spills much easier (lower surface tension!) Not a nice substance, best work outdoors. "Smells different though " Its very toxic to breath:( Link to comment Share on other sites More sharing options...
JohnA Posted February 19, 2006 Share Posted February 19, 2006 the fumes are toxic, hence the 'not nice substance' reference Not my first choice for eye-drops. Link to comment Share on other sites More sharing options...
Lucifer Posted February 19, 2006 Share Posted February 19, 2006 If you put model racing fuel in your engine, Feel free to call me when it goes bang..... that fuels is lubricated and I wouldnt like to say what it would do, and is quite viscious even at 5% Link to comment Share on other sites More sharing options...
Syed Shah Posted February 19, 2006 Share Posted February 19, 2006 Your are supposed to run a lube with meth anyway. Link to comment Share on other sites More sharing options...
Lucifer Posted February 19, 2006 Share Posted February 19, 2006 Your are supposed to run a lube with meth anyway. I think youll find thats only if you running it through hollies. Link to comment Share on other sites More sharing options...
Syed Shah Posted February 19, 2006 Share Posted February 19, 2006 Hollies? The Meth kits a guy on SF used to sell suggested use of lube in the meth, if running in higher concentrations. Same with most other meths kits AFAIK. Link to comment Share on other sites More sharing options...
Lucifer Posted February 19, 2006 Share Posted February 19, 2006 I was refering to Holly carbs, in which case you prob lookign at full blown meth /alc draggers. In which case you will need some mineral based lube, castor oil was agood bet in 1 part to 100. Link to comment Share on other sites More sharing options...
JamieP Posted February 19, 2006 Share Posted February 19, 2006 do you mix methanol with water... if so what ratio....cheers jamie Link to comment Share on other sites More sharing options...
Syed Shah Posted February 19, 2006 Share Posted February 19, 2006 Eirther way, your 1st comment is very OTT. Meth is commonly lubed, and will not make your engine got 'bang'. Link to comment Share on other sites More sharing options...
Lucifer Posted February 19, 2006 Share Posted February 19, 2006 Mix 50/50 but use more water than meth if in doubt, water is a very powerful power giver at our level. Syed, I take it back, im sure everyones engines will be fine. Link to comment Share on other sites More sharing options...
JohnA Posted February 20, 2006 Share Posted February 20, 2006 Your are supposed to run a lube with meth anyway. I wouldn't think so. As said before, pure methanol and distilled water. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 20, 2006 Share Posted February 20, 2006 Methanol is a constituent in some model aircraft / car / boat / helicopter / whatever, engines. Normally mixed with other ingredients it is also available separately, from model shops, although iin small quantities it's an expensive way to buy it. You only need to worry about adding an upper cylinder lubricant in two stroke engines or when it is the sole propellant. Link to comment Share on other sites More sharing options...
JohnA Posted February 20, 2006 Share Posted February 20, 2006 Exactly, the mix is meant for two-stroke engines. And the yank carbs, as Martin said. Here we're talking about fuel injected four-stroke engines using the Aquamist pump, and any rogue additive is a risk for blocked nozzles or a damaged pump. To be safe: if in doubt, *ask* first, don't improvise and hope for the best. Link to comment Share on other sites More sharing options...
