Bobbeh Posted January 17, 2006 Share Posted January 17, 2006 yes u are wrong, they have about 280bhp at the fly No you are. They're not all 280bhp as standard, they range from around 240- 280 depending on the model. Link to comment Share on other sites More sharing options...
ADD Posted January 17, 2006 Author Share Posted January 17, 2006 yeah it the type R he has, just confirmed it with him Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted January 17, 2006 Share Posted January 17, 2006 No you are. They're not all 280bhp as standard, they range from around 240- 280 depending on the model.well he was definitely wrong!! most of them are bout 280 at fly standard, jesus. Link to comment Share on other sites More sharing options...
Tom Posted January 17, 2006 Share Posted January 17, 2006 If he has 320 atw as appose to fly wheel then he'll probably be pulling away, get someone to film when you have a go Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted January 17, 2006 Share Posted January 17, 2006 If he has 320 atw as appose to fly wheel then he'll probably be pulling away, get someone to film when you have a go lol probably?? if hes running 320 rwhp then hes runnin at least 400 fly, and with the weight difference hel be gone waaay in front! Link to comment Share on other sites More sharing options...
nismo_lp Posted January 17, 2006 Share Posted January 17, 2006 Power at Flywheel (BHP) : 237 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 218.91 0 - 60 (Secs) : 5.12 0 - 100 (Secs) : 12.80 60 - 100 (Secs) : 7.68 Quarter Mile (Secs) : 13.48 Terminal Speed (MPH) : 102.61 Drag Strip Quarter Mile (Secs) : 13.38 Drag Strip Terminal Speed (MPH) : 103.80 So thats a standard 237bhp rx7 ... Yes i know the RX7 weighs more but i had to use that weight to calibrate the calculator. ...................................................................................................... Power at Flywheel (BHP) : 325 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 300.20 0 - 60 (Secs) : 4.08 0 - 100 (Secs) : 9.57 60 - 100 (Secs) : 5.49 Quarter Mile (Secs) : 12.36 Terminal Speed (MPH) : 113.60 Drag Strip Quarter Mile (Secs) : 12.26 Drag Strip Terminal Speed (MPH) : 114.92 ...and that according to a BHP calculator is how an rx7 should perform with 325bhp at the fly! Link to comment Share on other sites More sharing options...
ADD Posted January 17, 2006 Author Share Posted January 17, 2006 Power at Flywheel (BHP) : 237 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 218.91 0 - 60 (Secs) : 5.12 0 - 100 (Secs) : 12.80 60 - 100 (Secs) : 7.68 Quarter Mile (Secs) : 13.48 Terminal Speed (MPH) : 102.61 Drag Strip Quarter Mile (Secs) : 13.38 Drag Strip Terminal Speed (MPH) : 103.80 So thats a standard 237bhp rx7 ... Yes i know the RX7 weighs more but i had to use that weight to calibrate the calculator. ...................................................................................................... Power at Flywheel (BHP) : 325 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 300.20 0 - 60 (Secs) : 4.08 0 - 100 (Secs) : 9.57 60 - 100 (Secs) : 5.49 Quarter Mile (Secs) : 12.36 Terminal Speed (MPH) : 113.60 Drag Strip Quarter Mile (Secs) : 12.26 Drag Strip Terminal Speed (MPH) : 114.92 ...and that according to a BHP calculator is how an rx7 should perform with 325bhp at the fly! bloody hell that's a quick car! maybe i wont play with him then Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted January 17, 2006 Share Posted January 17, 2006 hmm Link to comment Share on other sites More sharing options...
nismo_lp Posted January 17, 2006 Share Posted January 17, 2006 bloody hell that's a quick car! maybe i wont play with him then Thats according to a web site 'bhp and performance' calculator .... ive tried it with some standard cars and it seems to be fairly close to the proper figures once the weight is set up correctly! Your supra must be running what.... 400bhp????? Link to comment Share on other sites More sharing options...
nismo_lp Posted January 17, 2006 Share Posted January 17, 2006 UK Manual Supra (326bhp) Power at Flywheel (BHP) : 326 Weight without Driver (KG) : 1485 Power to Weight Ratio (BHP Per Ton) : 223.05 0 - 60 (Secs) : 5.04 0 - 100 (Secs) : 11.76 60 - 100 (Secs) : 6.72 Quarter Mile (Secs) : 13.31 Terminal Speed (MPH) : 106.41 Drag Strip Quarter Mile (Secs) : 13.21 Drag Strip Terminal Speed (MPH) : 107.61 ....................................................................................................... Supra with (400bhp) Power at Flywheel (BHP) : 400 Weight without Driver (KG) : 1485 Power to Weight Ratio (BHP Per Ton) : 273.68 0 - 60 (Secs) : 4.34 0 - 100 (Secs) : 9.58 60 - 100 (Secs) : 5.24 Quarter Mile (Secs) : 12.54 Terminal Speed (MPH) : 114.40 Drag Strip Quarter Mile (Secs) : 12.44 Drag Strip Terminal Speed (MPH) : 115.69 but you would have to add about half a sec (i think) due to it being an auto Its not exact but it does show how power to weight works. The figures to the 326bhp supra is pretty much what i should be running and the 1/4 time and terminal speed are EXTREMELY close. Link to comment Share on other sites More sharing options...
nismo_lp Posted January 17, 2006 Share Posted January 17, 2006 rx7 with about 480bhp at the fly... Power at Flywheel (BHP) : 480 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 443.37 0 - 60 (Secs) : 3.36 0 - 100 (Secs) : 7.25 60 - 100 (Secs) : 3.88 Quarter Mile (Secs) : 11.48 Terminal Speed (MPH) : 125.88 Drag Strip Quarter Mile (Secs) : 11.38 Drag Strip Terminal Speed (MPH) : 127.33 Fookin hell! Link to comment Share on other sites More sharing options...
Rich Posted January 17, 2006 Share Posted January 17, 2006 off the mark its going to basically come down to who is the best driver as both cars running the power they are will struggle to get the power down unless they can really drive. Link to comment Share on other sites More sharing options...
Tom Posted January 17, 2006 Share Posted January 17, 2006 lol probably?? if hes running 320 rwhp then hes runnin at least 400 fly, and with the weight difference hel be gone waaay in front! Like I said he will be pulling away? and the supe will be tipping 400 too but the supe has a HUGE amount more torque which is what will be needed, I dont believe the rex will be pulling away that fast. Link to comment Share on other sites More sharing options...
RedM Posted January 17, 2006 Share Posted January 17, 2006 Remember not to go faster than the speed limit if you're not posting in the members only section! Link to comment Share on other sites More sharing options...
Keith C Posted January 17, 2006 Share Posted January 17, 2006 UK Manual Supra (326bhp) Weight without Driver (KG) : 1485 Heh - try another 100kg. Link to comment Share on other sites More sharing options...
Tom Posted January 17, 2006 Share Posted January 17, 2006 Heh - try another 100kg. It all works out anyway as the rx7 type r is 1270kg not 1100, but the supe is around 1500. Link to comment Share on other sites More sharing options...
Gazboy Posted January 17, 2006 Share Posted January 17, 2006 I reckon he'd paste you from 40-100 then you'd sail past. Link to comment Share on other sites More sharing options...
scott23 Posted January 17, 2006 Share Posted January 17, 2006 i thinkthe 7 will just have the edge due to owning 1 with370.9at the fly and racing my mate inhis supra. but my seem to slow at 140mph so if your daring Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted January 17, 2006 Share Posted January 17, 2006 It all works out anyway as the rx7 type r is 1270kg not 1100, but the supe is around 1500. rx7 is 1270kg??? shit thats heavier than my impreza type r, strange that Link to comment Share on other sites More sharing options...
Clarkey Posted January 17, 2006 Share Posted January 17, 2006 I reckon he'd paste you from 40-100 then you'd sail past. That's if it get's to 100. The engine rebuild costs must be horrendous! Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 17, 2006 Share Posted January 17, 2006 rx7 with about 480bhp at the fly... Power at Flywheel (BHP) : 480 Drag Strip Quarter Mile (Secs) : 11.38 Drag Strip Terminal Speed (MPH) : 127.33 Fookin hell! wow thats close i ran 11.4 at 128 mph mine is just over 500bhp Link to comment Share on other sites More sharing options...
Markie Posted January 17, 2006 Share Posted January 17, 2006 rx7 with about 480bhp at the fly... Power at Flywheel (BHP) : 480 Weight without Driver (KG) : 1100 Power to Weight Ratio (BHP Per Ton) : 443.37 0 - 60 (Secs) : 3.36 0 - 100 (Secs) : 7.25 60 - 100 (Secs) : 3.88 Quarter Mile (Secs) : 11.48 Terminal Speed (MPH) : 125.88 Drag Strip Quarter Mile (Secs) : 11.38 Drag Strip Terminal Speed (MPH) : 127.33 Fookin hell! I would have to see it to beleive it I am affraid Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 17, 2006 Share Posted January 17, 2006 I would have to see it to beleive it I am affraid keep an eye out for my red rx7 for next year if the guy drags it i did 11.4 at 128mph et Link to comment Share on other sites More sharing options...
JohnA Posted January 18, 2006 Share Posted January 18, 2006 Heh - try another 100kg. Plus the driver (in both cases) Yet another 100kg perhaps:whip: I've driven the '280bhp from the factory' RX7 and while it's nice and nimble, I doubt that it would touch a good supra over a ton. Link to comment Share on other sites More sharing options...
supRo Posted January 18, 2006 Share Posted January 18, 2006 Back to the original topic - Did the race happen? Link to comment Share on other sites More sharing options...
