Rob Posted July 11, 2003 Share Posted July 11, 2003 Having fitted me CW standard pads last weekend, minus the shims, I find if I reverse slightly and apply brakes, there is a double knock from the front, which then repeats if I drive forward and apply brakes. It sounds like the discs moving, but that cannot be as the wheel bolts are all secure. Any ideas? Link to comment Share on other sites More sharing options...
Terminator Posted July 11, 2003 Share Posted July 11, 2003 Sounds like the pads seating, If the brakes are clean there has to be a very small amount of play to allow the pads to move. As the pads age the sliding tracks get full of crud which reduces the travel. I think you have slightly more travel on JDM brakes. I don't think it is anything to worry about Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 11, 2003 Share Posted July 11, 2003 When I first fitted the UK brakes to my car, I had no shims to start with and I got the same thing. I expect it'll be OK when you fit the shims... I still get it slightly from the rear brakes though, but only faint. Link to comment Share on other sites More sharing options...
Rob Posted July 11, 2003 Author Share Posted July 11, 2003 Phew, thats allright then. Thanks very much Link to comment Share on other sites More sharing options...
Keith C Posted July 11, 2003 Share Posted July 11, 2003 I get it all the time on my car. I figure it's just the pads shifting slightly in the calipers. I have the shims and it still does it, but it's been doing it a while now and my wheels haven't fallen off so it's probably ok Link to comment Share on other sites More sharing options...
womble Posted July 11, 2003 Share Posted July 11, 2003 Mine also does it but it's by no means just a knock, it rattles that much it sounds like a milk float doing 80 oner cobbles !. Stops well though . Link to comment Share on other sites More sharing options...
Guest Jonno2020 Posted July 13, 2003 Share Posted July 13, 2003 I have the same problem from the rear NS wheel. The frist sign is a squeel and then only when I apply the brakes gently does the noise occur. It only seems to make a noise when the brakes are hot. Had it checked twice by Toyota and they have suggested fitting fibre shimms.. Will try it next week and see. Bloody loud noise though. Link to comment Share on other sites More sharing options...
Rob Posted July 13, 2003 Author Share Posted July 13, 2003 Fibre shims? as in carbon fibre? at Toyota prices? alone? in a girls school? with my reputation? surely not? sorry deviated there a bit Link to comment Share on other sites More sharing options...
Guest Jonno2020 Posted July 14, 2003 Share Posted July 14, 2003 The pads I have fitted are green EBC one's, their website offers the shims free of charge!! Not bad eh? Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 14, 2003 Share Posted July 14, 2003 Originally posted by Jonno2020 The pads I have fitted are green EBC one's Oh no......... Do a search on 'EBC' or 'Green Stuff' before it's too late. Link to comment Share on other sites More sharing options...
Guest Jonno2020 Posted July 14, 2003 Share Posted July 14, 2003 Thanks for the really constructive comment, really helped!! Must come straight to you next time I need to know where to put the oil..... Mind you, I know a few places!! Link to comment Share on other sites More sharing options...
Ian C Posted July 14, 2003 Share Posted July 14, 2003 Don't ask what's a good oil to use when you do, otherwise someone might warn you about a bad product and then you'll have to pick your toys up post-pram ejection -Ian Link to comment Share on other sites More sharing options...
Guest Jonno2020 Posted July 14, 2003 Share Posted July 14, 2003 Thanks, will bear that in mind! Will first have to stop pram as the contents seem to be missing, they must have exited through window!! Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 14, 2003 Share Posted July 14, 2003 Originally posted by Jonno2020 Thanks for the really constructive comment, really helped!! Must come straight to you next time I need to know where to put the oil..... Mind you, I know a few places!! Link to comment Share on other sites More sharing options...
