what exhaust
owenreme
about £600, as to photos, you would have to wait till daytime.
They look nice and exit at a slight slant. Possibly one of the most popular exhausts.
Have a look at my garage to check out the XERD header I have fitted in addition to the exhaust.
Gives good gains, with claimed 18+ bhp.
I think there is a lot to improve the performance of the NA, considering all Honda's are NA and they have loads of performance parts that work!
Its down to two things:
1) Forced induction produces massive gains, so the cost per bhp addition is lower.
2) How much you want to spend?
NA Improvements are, longer duration cams, larger injectors with associated fuel piggy back ECU, adjustable cam gears, lighter pulleys, decats, thinner head gasket (increases compression, but also increases heat and possible damage)
Head skimming, port polishes, longer headers to increase torque, induction, bigger induction manifold and throttle bodies.
:ok:
