Loss of fuel pressure
Noz
 Share
Last night car got stuck at 3k rpm and because unresponsive.
Sadly having to arrange recovery this morning. As long as its still there kf course 😂
It feels electrical as if the throttle body just disconnected. Have an electric throttle.
Car then proceeded to not start.
Any off the cuff ideas?
Edited by Noz
Further information (see edit history)
  • Noz changed the title to Loss of fuel pressure
1 hour ago, Mike2JZ said:
If the pump is on but cant build pressure just check rubber hose inside fuel tank hasnt ripped. If the pump dosent run at all then probably faulty
The pump turns on. Hits 4 bar. Then dies.
Will check the pipe tomorrow. Thank you for that idea.
  • 3 weeks later...
It turned out it was the fuel pump. Grams. 320 lph.
Annoyingly.. the new one just failed.
Any advice on what fuel filters to use. I'll get a new pump but likely change the filter too. Cleaning the contacts I'm hoping may also help. Really no idea why this has happened again.
I'll be travelling with a spare pump soon 😂
 Share
