Best turbo setup on na-t
jza800
I have en supra na, where i am gonna put an turbo setup on it, what is the best turbo setup to that engine what camshaft should i get. the hp range is 500 hp.. i have en w58 gearbox, is that fine to 500 hp, or should i get en r154 box.. i like to get another air intake, and coil packs.. what clutch should i go for?
Firstly you need to decide on a budget
Budget for ECU, injectors, exhaust, intercooler, sensors etc.
W58 won't do 50 0hp, R154 or V160/1 or BMW conversion would be needed.
You can save money from not buying cams, stock cams will make that power easily, just do a compression test, get a GTE headgasket and boost it!
Aim for 400hp. 500hp risks the transmission as mentioned and can second the fact cams aren't needed for anything under 700hp.
Get a 56 or 58mm turbo. You can leave stock compression then (no head gasket needed).
Srd sell a low cost standalone. A nice route to take.
Whifbitz do a coil conversion and 4 inch intakes.
I'd use the search function and then put together a proposed spec of what you think you're missing.
