zap Posted April 3, 2021 Share Posted April 3, 2021 Hi all, Is there anyone on here that refurbishes headlights? I've got UK spec glass ones and the passenger one is always full of condensation, if I take it off and dry it out it's fine for a couple of days but then get wet again. I have tried sealing around the bulb sockets etc but still no joy, the drivers side has no issues at all. Thanks. Link to comment Share on other sites More sharing options...
tayr Posted April 3, 2021 Share Posted April 3, 2021 @Noz Link to comment Share on other sites More sharing options...
Noz Posted April 3, 2021 Share Posted April 3, 2021 Is it a leak issue or a full refurb issue. How do your inserts look. Have you tried covering everything with sealant. Link to comment Share on other sites More sharing options...
zap Posted April 5, 2021 Author Share Posted April 5, 2021 Hi Noz, The problem is with the nearside headlight. It is always full of condensation and the insert is starting to colour up around the outer edge (looks like rust). I have tried siliconing around all of the bulb holders because I read somewhere that there are different size bulb fittings! My next option was to seal around the outer edge but I thought I might get some ideas here first, either way the headlight will need some sort of refurb. The offside light is perfect, it has the same bulbs fitted but no sign of condensation or corrosion at all. Cheers. Link to comment Share on other sites More sharing options...
