How-To Install SupraStick & Flappy-Paddles + User Register ***
Flappy-Paddle options. http://www.mkivsupra.net/vbb/group.php?discussionid=144&do=discuss
Tip: :thumbs:
When using OE Lexus Flappy-Paddles, use these (mono-directional) ground switching circuits to trigger relays for 12v SupraStick manualised gear-change feeds.
vbpgimage.php?do=full&p=21315&d=1339286581
Flappy-Paddles to wires 10 upshift & 17 downshift.
Tip: :thumbs:
For Supra installation, using the above interface relay system, the redundant Manu button can be linked to wire 2, Auto/Manual switching and the O.D. button linked to wire 20, Shift-Table selection.
Which provides OE switch-function & dash-information display-lights for Manual/Auto & Race/Eco shift-options. :cool:
Via clock-spring - Change-up LED in hub
Solenoid no. 1. loom-wire is cut and bridged with wires 4 & 13, solenoid no. 2. loom-wire is cut and bridged with wires 5 & 14, lock-solenoid loom-wire is cut and transmission-tail connected to wire 15.
Wire no. 8. can be piggy-backed onto transmission speed-sensor (16ish-blips per wheel-rev) or alternatively, if you have, for a better signal link to an ABS sensor? (96-blips per wheel-rev)
:think: That only leaves wire 3. to Ignition +, wire 1. to Ground - and three little piggies to back onto ECU loom-wires. ;)
Wire no. 9, TPS. Wire no. 11, RPM. Wire no. 12, Brake Signal.
Supra ECU pin diagram. http://www.jegs.com/InstallationInstructions/0/017/017-30-1100.pdf
Tip: :thumbs:
2JZ-GE: Crank sensor = 12
2JZ-GTE: Crank sensor = 12
2JZ-GTE VVTi: Cam sensor = 3
1JZ-GTE: Crank sensor = 12
1JZ-GTE VVTi: Cam sensor = 3
1UZ-FE: Crank sensor = 12
1UZ-FE VVTi: Cam sensor = 2
Tips: :thumbs:
The only loom cuts are the 3 solenoid wires, all other joints are piggybacked.
Vehicle tyre size = Diameter in inches?
Tyre size calculator. https://tiresize.com/tyre-size-calculator/
Supra diff's specifications. http://mkiv.supras.org.nz/specs.htm
Homers Transmission Calculator could be of use too? http://www.mkivsupra.net/vbb/showthread.php?225050-Supra-specific-gear-diff-ratio-and-tyre-size-calculator
:trophy: Now you're Flappy-Paddling. :trophy:
SupraStick was designed when Window 98 was about and interfaced using Hyper Terminal software and a serial port. To communicate with SupraStick using modern hardware and software and USB to serial lead will be needed.
An alternative to Hyper Terminal is a program called PuTTY.
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
A little configuration of the COM port will be needed (mine happens to be COM5 but it can be any available port). The best settings are:
- Baud rate: 19200
- Flow control: None
- Default everything else
When PuTTY is installed, set a few serial settings to match that of your COM port.
Update the serial port section.
:hi: Thank you Mike.
(Please note: Vehicle Settings shown in Mike's pic and again below, are for 1UZ-FE VVT-i with; cam-sensor rpm signal - 3.769 diff - 18" wheels - 265 35 tyres - ABS speed-signal.)
Settings for 1J & 2J non VVT-i install using crank-sensor & transmission no. 2 speed-sensor.
1. = 12. (Crank-sensor)
2. = 4. (Transmission no. 2 speed-sensor)
3. = 41 or 38? Diff ratio. http://mkiv.supras.org.nz/specs.htm
4. = Diameter of tyre. https://tiresize.com/tyre-size-calculator/
5. = 2800. (Baseline - can be adjusted to suit)
6. = Bespoke. (How-To explained in PDF)
7. = Bespoke. (How-To explained in PDF)
jagman, reports that he also prefers puTTy to Hyperterminal. :slap: and has provided pics with a few words of his Soarer 1JZA80-GTE Installation.
Before
Showing the rear of the clock-spring - note 6 tracks - but only 4 used on soarer - these are cut (3) and used to provide up /down/ and earth , new wires fed to here from supra stick , and the old cut wires are used for the cruise control buttons. The 4th wire is for the horn and remains untouched.
This many wires
Note two relays used for paddles - centre of pic between syvecs and stick - note fused supply in centre below syvecs - relays /switches/stick/ all fused separately - suprastick has no fused supply supplied.
Eventually it all fits here
  • 7 months later...
Mapping Suprastick has always been a PITA because the software kept dropping out every few minutes.
The problem would appear to be that Suprastick doesn't like serial to USB adaptors.
I have now bought an old Windows 98 laptop with a serial port and used this to map Delboy52 Mike's Suprasticked Supra with no issues whatsoever, if anyone needs it, just ask.
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
 Share
