Making my own AN fittings - BRASS
Noz
I've toyed with this for years. Mainly due not knowing the end goal. Years ago when I made some prototypes, my goal was to make a superior fitting. But so many companies provide such a nice finish, I just bailed.
But, wanting to make my own products. For my own engine.
Has anyone ever considered using brass? I've never seen it and I don't see any reason there would be a chemical reaction with engine fluids.
I'd like to use brass for all sorts. So at this moment, I'm not isolating a single use of that material.
What would you be making out of brass that you cant buy in any other, lighter and cheaper metal?
I'd like to do something a bit unique. Supra engine bays have been done to death.
I like making my own parts. If I can combine making something new. I'll likely buy some bits and consider brass plating if I dont want to make everything. Like cam covers. Only as I cant be doing with faffing with tolerances. I've done that when I made my own billet spark cover, which was a 3D scanned version of the GTE cover.
Just thought I'd add some touches before I go mad.
Want my engine to look a bit more interesting.
If someone else can buy it. I dont see the point. I'd rather save the cash than keep up with so many others bottomless pocket builds.
