Ohshi7 Posted August 20, 2019 Share Posted August 20, 2019 Hey guys, i have started working on my 95 Supra, Basically im looking for a wiring diagram to re-pin my 1jz harness into my 2jzge body harness. I know it has been done before but i can't seem to find anything on any of the forum sites or if i do it usually has been deleted. If anyone would be able to help that would be incredible as im trying to finish the car up as urgent as possible. Thanks Link to comment Share on other sites More sharing options...
Shane Posted August 22, 2019 Share Posted August 22, 2019 Everything you need is probably here: http://wilbo666.pbworks.com/w/page/41678224/2JZ-GE%20JZA80%20Supra%20Engine%20Wiring Link to comment Share on other sites More sharing options...
Konrad Posted August 22, 2019 Share Posted August 22, 2019 Everything you need is probably here: http://wilbo666.pbworks.com/w/page/41678224/2JZ-GE%20JZA80%20Supra%20Engine%20Wiring I used this to make harness between 1jz engine and 2jz internal one without cutting single wire Link to comment Share on other sites More sharing options...
Ohshi7 Posted August 24, 2019 Author Share Posted August 24, 2019 Essentially I wanted to re pin the connectors, will it be one of those diagrams where I need to match either wire to the same sensor ? ( If that makes sense ) Link to comment Share on other sites More sharing options...
Konrad Posted August 24, 2019 Share Posted August 24, 2019 its more about matching what's on the end of 1JZ engine loom with what you got inside Supra (Orange and grey plug mainly) Link to comment Share on other sites More sharing options...
Ohshi7 Posted September 8, 2019 Author Share Posted September 8, 2019 So I basically have started matching the pins to each other on the both diagrams but Ive run into a road block, with about 10 wires would you know which ones go where if I was to write them down on here? Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 8, 2019 Share Posted September 8, 2019 Yes go for it Link to comment Share on other sites More sharing options...
Ohshi7 Posted September 8, 2019 Author Share Posted September 8, 2019 Okay so I'll write them down on what I have done so far and if anyone wants to correct me please do so (Legend G(grey) O(orange) W(white) P(pin) ) 1jz orange plug 1j P1 - 2jP21 1jP2 - 2jGP17 1jP4 - 2jGP5 1jP5 - 2jGP6 1jP6 - 2jP8 1jP2 - 2jP2 1jP8 - 2jP28 1jP9 - 2jP25 1jP11 - Unknown 1jP18 - Unknown 1jP19 - 2jP6 1jP20 - 2jP25 1jP23 - 2jP33 1jz Grey plug 1jP1 - Unknown 1jP2 - 2jGP25 1jP3 - unknown 1jP4 - unknown 1jP5 - unknown 1jP6 - unknown 1jP7 - unknown 1jP9 - 2jGP19 1jP10 - unknown 1jp11 unknown 1jp12 unknown 1jp13 unknown 1jp15 unknown 1jp16 unknown 1jp17 unknown 1jp18 unknown 1jp19 unknown 1jp20 Unknown 1jp21 unknown 1jp23 - 2jGP18 1jp25 - 2jGP25 1jz Grey plug #2 1jp1 - 2jp3 1jp - 2jp11 1jp6 - 2jp4 1jp7 - 2jGP11 1jp11 - 2jp13 1jp12 - 2jp23 1jp13 unknown 1jp16 - 2jp14 1jz grey plug #3 1jp1 - 2jGP8 1jp2 unknown 1jp5 - 2jp34 1jp6 unknown 1jp7 unknown 1jp8 unknown 1jp10 - 2jGP1 1jp11 - 2jp32 1jp14 - 2jGP4 - - - Updated - - - So maybe a little more then 10... My bad Link to comment Share on other sites More sharing options...
Ohshi7 Posted September 8, 2019 Author Share Posted September 8, 2019 I just put them underneath Link to comment Share on other sites More sharing options...
Ohshi7 Posted September 16, 2019 Author Share Posted September 16, 2019 So has anyone been able to crack the code yet? Link to comment Share on other sites More sharing options...
Shane Posted September 16, 2019 Share Posted September 16, 2019 So has anyone been able to crack the code yet? Those numbers mean nothing to me I am afraid. I recently did a 1uz conversion into a 2jz gte, ok not the same I apreciate, but principle the same. Using the 1uz ECU pinout and the details in the Wilbo666 link I was able to wire the whole thing and that was without half of the connectors from both the 1uz and the 2JZ, so assuming you have pinouts for both models you should be able to cross reference what goes where. If you have all the connectors from both cars it should be even easier. Link to comment Share on other sites More sharing options...
