jza800 Posted March 23, 2019 Share Posted March 23, 2019 Somebody have some experience with this ecu? i have tried google but that dont help me much?? is it a good upgrade ecu, or?? Link to comment Share on other sites More sharing options...
Shane Posted March 23, 2019 Share Posted March 23, 2019 Somebody have some experience with this ecu? i have tried google but that dont help me much?? is it a good upgrade ecu, or?? Pull the lid off and look inside because that looks like a stock ecu with a big sticker on it. None of the Vi-pec units I can find look like that tbh. Link to comment Share on other sites More sharing options...
jza800 Posted April 6, 2019 Author Share Posted April 6, 2019 it seems to be right enough.. but it says it is to a single turbo, i run twin turbo.. can i use it??? it is possible to test it work without putting it in a car??? Link to comment Share on other sites More sharing options...
Swampy442 Posted April 6, 2019 Share Posted April 6, 2019 Id email ViPec sih the serial number, see if the can tell you anything about it Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 6, 2019 Share Posted April 6, 2019 Vipec is now Link ECU. Their V88 plug and play for supra is similar to the offering from Link ECU. Still quite a capable ECU. Like the Link ECU, out of the box the plug and play ecu will not support sequential twin turbo operation, but it will support TTC or Single turbo. If you want to run sequential turbo's on a plug and play, then check out this guide I wrote a while back. Pinouts and functionality should be similar on Viper board. http://www.mkivsupra.net/vbb/showthread.php?350005-SQ-TTS-Guide-Sequential-TTC-SQ-TTC-Switching-Twins-and-Standalone-ECU Link to comment Share on other sites More sharing options...
