Looking for 2JZ GTE automatic Engine standard ECU
cooin
 Share
Numbers here...
89661-14490
Supra ECU Part Numbers (Auto, J-Spec, NA):
- 89661-14600 (93-97)
- 89661-14810 (97-99)
Supra ECU Part Numbers (Auto, J-Spec, TT):
- 89661-14490 (9305-9310)
- 89661-14491 (9310-9605)
Supra ECU Part Numbers (5Spd, J-Spec, NA):
- 89661-14610 (only number listed)
Supra ECU Part Numbers (6Spd, J-Spec, TT):
- 89661-14500 (9305-9310)
- 89661-14501 (9310-9605)
- 89661-14770 (9605-9709)
- 89661-14830 (9709-)
Thank you Scooter, that is really helpful, I believe I need :
If there is someone got it, please let me know, thank you guys ~
I think essentially they are yes certainly interchangable, there are no model changes corresponding to the date change and I can only suspect something else was changed (presumably improved!?), supplier, boards, solder, sealant used in its production etc.
 Share
