Icsea Posted September 19, 2018 Share Posted September 19, 2018 I've had the undercover off on my bonnet and all the pipes are right and dry when I put water through them but my drivers side barely throws any water out, I've tried a needle in the slots and it didn't change it at all, don't know if this is common or maybe my pump is on the way out? TIA Dan Link to comment Share on other sites More sharing options...
blythmrk Posted September 19, 2018 Share Posted September 19, 2018 Try removing the jet from the bonnet and put it in a cup of boiling water I did this years ago and was surprised at the amount of dirt that came out. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 19, 2018 Share Posted September 19, 2018 Filter in the reservoir could be choked up, jets bunged up or the pump is plain tired. Link to comment Share on other sites More sharing options...
Icsea Posted September 25, 2018 Author Share Posted September 25, 2018 Try removing the jet from the bonnet and put it in a cup of boiling water I did this years ago and was surprised at the amount of dirt that came out. Not to sound like an idiot but how do I get the jet from the bonnet? Link to comment Share on other sites More sharing options...
Scooter Posted September 25, 2018 Share Posted September 25, 2018 Use some, thin but strong plastic (like the clear stuff on packaged bolts/bulbs/kids toys). Gently slide it under the front or back of the nozzle (under the black rubber seal bit) and lift that end of the nozzle then do the front similarly, or try both (and lifting) if being awkward. If you detach the nozzle just be careful to ensure you don't lose the tube/hose down into the bonnet. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2018 Share Posted September 25, 2018 Carefully....Or you'll be respraying the bonnet Link to comment Share on other sites More sharing options...
