Marcc Posted September 5, 2018 Share Posted September 5, 2018 Hey guys! I’m running 10J rota wheels on the rear at for moment with a offset of 35 on a 265 tire. I haven’t rolled the fenders at all but they catch the edge of the fender just! Was wondering would going for a 9.5J et 38 with the same 265 tire would this fit further in to avoid missing the fender?! Or would I have to go for a 9.5J wheel with a 255 tire? I don’t really fancy going for a smaller tire but if I have to I might. Any feedback would be appreciated! :-) Thank You Quote Link to comment Share on other sites More sharing options...
fullthrottle Posted September 5, 2018 Share Posted September 5, 2018 I run a 295 on the rear with standard arches just rolled and I believe some people have even gone 315 on the rear so I guess you just need the correct wheel fitment Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 5, 2018 Share Posted September 5, 2018 Rough calc, half an inch is approx 12mm, so the 9.5" wheels will sit 6mm further in if they were just the same offset, as they are 38 as opposed to 35 then they will sit a further 3mm 'in' so a little over 9mm more clearance ( may even be too much depending on how you want it to look?) Quote Link to comment Share on other sites More sharing options...
TuneR Posted September 6, 2018 Share Posted September 6, 2018 I'm running a 10j +34 with a 255 tyre on Eibach springs and no rubbing, tbh i wanted to upgrade to a 265/275 but looking at this thread i mightn't bother. Dont want to roll the arch.... Quote Link to comment Share on other sites More sharing options...
ShawnPreece Posted September 6, 2018 Share Posted September 6, 2018 The offset figure is the main thing to consider here, if you are using a 9.5j instead of a 10j rim this will make no difference if still using the same size tyre as what is catching is the tyre which is 265mm wide on the outside edge so reducing the size of rim will keep this at 265mm wide on the outer edge and will just give a more "mushrooming" effect as the inner edge of the tyre (where the tyre meets the rim) will be pulled in by half an inch in total but the outside edge remains at 265mm so id stick with the 10j if it looks better on the rim. The offset being 38 instead of 35 will bring the wheel and tyre 3mm further in though so just need to work out if 3mm is enough, changing to a 255 tyre would help as you are reducing the outer width by 10mm (5mm each side) so that would bring the edge of the tyre 5mm further in too but as you say this means a 255 tyre which you'd rather keep at least a 265 if you can get the offset correct. Here is a thread I started which hopefully explains it a little more Quote Link to comment Share on other sites More sharing options...
Marcc Posted September 6, 2018 Author Share Posted September 6, 2018 Thanks guys! This is a massive help! :-) Quote Link to comment Share on other sites More sharing options...
