Brian_C1 Posted August 8, 2018 Share Posted August 8, 2018 Just in the process of removing the rear spats that came on my car, have one off and can't see any part number but they don't look like fiberglass to me, totally black and don't see any weave. Even on the cross section where they aren't painted they don't look like fiberglass but I'm no expert. Were any aftermarket spats made from plastic? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted August 8, 2018 Share Posted August 8, 2018 OEM rear spats are made from plastics and most aftermarket spats are fibreglass. If I remember correctly OEM will say toyota on the inside Quote Link to comment Share on other sites More sharing options...
Brian_C1 Posted August 8, 2018 Author Share Posted August 8, 2018 After checking further mine are definitely plastic, PPE (Polyphenylene Ether) to be exact, its stamped on the inside but barely visible with the paint. Don't see Toyota stamped anywhere though Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted August 8, 2018 Share Posted August 8, 2018 I can have a look at my spares later tonight and keep you posted Quote Link to comment Share on other sites More sharing options...
evinX Posted August 8, 2018 Share Posted August 8, 2018 The will be a dull black plastic on the inside with a metal bracket where the bottom screw goes through Quote Link to comment Share on other sites More sharing options...
Brian_C1 Posted August 8, 2018 Author Share Posted August 8, 2018 The will be a dull black plastic on the inside with a metal bracket where the bottom screw goes through Yep mine have the metal U-Bracket on the bottom, although the 2 rivets holding the bracket on have perished off so it'll need new rivets, mine are also a dull black on the inside. They're both off the car now so I'll put them up for sale tomorrow Quote Link to comment Share on other sites More sharing options...
