blythmrk Posted January 27, 2017 Share Posted January 27, 2017 I need to replace the rear seal where the prop joins the box (sorry about my lay mans description) I presume these are available from toyota or not? Cost? Are they pretty straight forwards change it looks easy enough! Thanks Link to comment Share on other sites More sharing options...
rider Posted January 27, 2017 Share Posted January 27, 2017 Refer this thread http://www.mkivsupra.net/vbb/showthread.php?306415-Getrag-V160-leaking-oil-Help-needed-to-find-correct-seal(s) I think there are two seals 90080-31031 90080-31029 Best to talk to CW - he isn't always instant at PM responses as he is a busy guy but you can call him and he can give you the definitive. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 28, 2017 Share Posted January 28, 2017 I have special low profile seals for the selector shaft (which is by far the commonest source of a leak on the back of the 6 speed Getrag), and propshaft flange seals in stock. The beauty of the low profile seals is you can carefully tap the existing seal further into the gearbox, and have TWO seals. Trying to get the original OUT is tricky, if you scratch the selector rod getting it out it will ALWAYS leak, new seals or not. E-mail if you need prices or want to order. [email protected]Â Â Thanks rider Link to comment Share on other sites More sharing options...
6speedmark Posted January 28, 2017 Share Posted January 28, 2017 Hi mate is this one the uk spec you got from me?? How's the diff doing on it??? Link to comment Share on other sites More sharing options...
blythmrk Posted January 28, 2017 Author Share Posted January 28, 2017 Yes another job on the old girl! Diff still the same I will be looking into that in the next few week worst case is a new crown wheel and pinion Link to comment Share on other sites More sharing options...
