samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 Yup... that was with a broken clutch and a blowing head gasket ...not no more!!!!!! Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 and anyway I can dream....can't I??? Quote Link to comment Share on other sites More sharing options...
JohnK Posted September 15, 2005 Share Posted September 15, 2005 Hi guys, been running really well on stock ECU, stock injectors. Been running at 1.2bar now done around 3500 miles and still going strong What size stock injectors and without an SAFC or e-manage? Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 Injectors are 440 stock j-spec and everything else is stock.. Have lots of bits to put on but won't do that till new manifolds and throttle bodies arrive.... Quote Link to comment Share on other sites More sharing options...
JohnK Posted September 15, 2005 Share Posted September 15, 2005 How does that turbo compare to a boostlogic T61? I take it you are monitoring the AFR's? Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 Greg is monitoring the AFR and will ask him how it compare with the T61 as I must be honest I have no idea bit thick where it comes to that....sorry Quote Link to comment Share on other sites More sharing options...
JohnK Posted September 15, 2005 Share Posted September 15, 2005 Only asking as running 1.2bar with 550 injectors on the stock ecu would run very lean on my car. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted September 15, 2005 Share Posted September 15, 2005 Worth reading: http://www.gtr.co.uk/forum/upload/showthread.php?t=42148 This was actually proved to be some dis-marketing from an american company. They Purposly nroke it and photographed it.. If you look the Tubine is brand new. And thus physical damage would not occur.. etc tec etc Quote Link to comment Share on other sites More sharing options...
supradibbs Posted September 15, 2005 Share Posted September 15, 2005 This was actually proved to be some dis-marketing from an american company. They Purposly nroke it and photographed it.. If you look the Tubine is brand new. And thus physical damage would not occur.. etc tec etc wow thats intretsting the more i read and hear the more i cant wait to get my car back after greg,sam and co have finished with it Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 See next post Quote Link to comment Share on other sites More sharing options...
samsupra37 Posted September 15, 2005 Share Posted September 15, 2005 Just for your info, I am running about 82% on the AFR not too bad at all I think!!!!! Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted September 15, 2005 Share Posted September 15, 2005 Sadly... that doesn't supprise me at all Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 16, 2005 Share Posted September 16, 2005 Just for your info, I am running about 82% on the AFR not too bad at all I think!!!!! wtf is 82% on the AFR?! -Ian Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted September 16, 2005 Share Posted September 16, 2005 Sorry poor old Samantha called me and asked what her Supra was running with regard to AFR she did not hear me right so here is what her Supra is running. AFR: 15.8 Lamda: 1.02 Her Injectors at 6400 rpm are running at 84% of duty. Intake-Charge Temperature:123 degrees F Hope that gives you the info you need. Quote Link to comment Share on other sites More sharing options...
JohnK Posted September 16, 2005 Share Posted September 16, 2005 AFR 15.8 at what boost, Id like to know it at full throttle / boost. If that is at full chat I'd like someone (Ian / Alex?) to tell me how that turbo compares to a boostlogic T61. Also what power are you putting out? Quote Link to comment Share on other sites More sharing options...
Alex Posted September 16, 2005 Share Posted September 16, 2005 15.8:1 on boost is early bath time. You will blow the engine up...sooner or later. You should be at worst at 12.5:1 on full boost. John, to compare the twqo turbo's we'd really need a dyno sheet for both, and to have them run back to back on the same car....but RPM's in 5th are a good indicator of how big the turbo is. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 16, 2005 Share Posted September 16, 2005 Sorry poor old Samantha called me and asked what her Supra was running with regard to AFR she did not hear me right so here is what her Supra is running. AFR: 15.8 Lamda: 1.02 Her Injectors at 6400 rpm are running at 84% of duty. Intake-Charge Temperature:123 degrees F Hope that gives you the info you need. I thought you might have meant duty instead. Er, 15.8:1 is great under closed loop and idling conditions, at the outer-swing of the closed loop cycle. You can't seriously be running that on boost? 1.2bar? On 440's? I hope you kept the cash you saved by not upgrading the fuel system or mapping it - it's gonna come in handy real soon. -Ian Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 17, 2006 Share Posted August 17, 2006 My first ressurection post:) Did any ever find out if the AFR's quoted above were on idle or at WOT? Quote Link to comment Share on other sites More sharing options...
Clarkey Posted August 17, 2006 Share Posted August 17, 2006 LOL! I didn't realise this was an old thread - till the end! I think they must be on WOT - as on cruise & idle the duty cycle can't be that high !? Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 17, 2006 Share Posted August 17, 2006 LOL! I didn't realise this was an old thread - till the end! I think they must be on WOT - as on cruise & idle the duty cycle can't be that high !? 15.5:1 on wot is dangerously Lean which is why i ask. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted August 17, 2006 Author Share Posted August 17, 2006 just a bit old Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 17, 2006 Share Posted August 17, 2006 just a bit old Well done Einstein:D Quote Link to comment Share on other sites More sharing options...
lockys96 Posted August 17, 2006 Author Share Posted August 17, 2006 thanks bob barker Quote Link to comment Share on other sites More sharing options...
wkdtime Posted August 17, 2006 Share Posted August 17, 2006 thanks bob barker Just had to look up who he is, way way before my time! Quote Link to comment Share on other sites More sharing options...
lockys96 Posted August 17, 2006 Author Share Posted August 17, 2006 price is wrong bitch, is happy gilmore before your time then? Quote Link to comment Share on other sites More sharing options...
