evinX Posted March 23, 2016 Share Posted March 23, 2016 Got a replacement airvent as mines all floppy and opens and closes when it wants For the life of me and i cant get it out, dropped both glove boxes and only found 2 tabs but the plastic surround wont release. I tried to pry out the vent with the square tabs at the top and bottom but if i go too far it might break. Would like to crack this one in the coming weekend so anyone done this before? Kev Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 23, 2016 Share Posted March 23, 2016 I think these are bolted to the IP reinforcement.. They only come off with the dash out.. Link to comment Share on other sites More sharing options...
evinX Posted March 23, 2016 Author Share Posted March 23, 2016 Thats what im thinking, theres a way to remove them without the surround but i cant get the knack of it Link to comment Share on other sites More sharing options...
Tsia Posted March 23, 2016 Share Posted March 23, 2016 Irish screwdriver should get them out. Link to comment Share on other sites More sharing options...
evinX Posted March 23, 2016 Author Share Posted March 23, 2016 irish screwdriver should get them out. Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 23, 2016 Share Posted March 23, 2016 If you remove the upper glove box, you'll find one or two screws on the side of the vent. The last screw is hidden behind it, right at the top. It's a total prick to get out, I ended up using a ph2 screwdriver bit on an adaptor (to fit a 1/4" ratchet), and manged to get it undone using my fingers on the bit If you look at your replacement one, you'll see the slot in the top. The screw goes through that Link to comment Share on other sites More sharing options...
masterfett Posted March 24, 2016 Share Posted March 24, 2016 If you remove the upper glove box, you'll find one or two screws on the side of the vent. The last screw is hidden behind it, right at the top. It's a total prick to get out, I ended up using a ph2 screwdriver bit on an adaptor (to fit a 1/4" ratchet), and manged to get it undone using my fingers on the bit If you look at your replacement one, you'll see the slot in the top. The screw goes through that as above! mine has been missing since ive had the car. so if anyone has a spare one hanging about drop me a pm. Link to comment Share on other sites More sharing options...
