Rear Light failure light
Tomyspeedy
So i've recently changed the rear lights for led bulbs.
They all worked correclty before doing so and they all work correctly now...great you might be thinking...
well I've also got a rear light failure light on the dash that comes on as soon as you turn the headlights/sidelights on. It also illuminated the brake warning light aswell ((!))
So I took a hint and changed the rear brake light bulbs back to filaments, which sorted the dash lights.
My question now is, what do I need to change to prevent the rear bulb warning light illuminating if i want to run led bulbs?
Which component could I change to detect a failure in the led light?
I'm presuming that it's a simple lowering of resistance in the brake circuit that's throwing the problem, I just don't have enough knowledge of the system to know what I could do to fix it! :(
I really don't want to alter the circuit in a permanent way. I was hoping that there would be a component I could change.. In the indicator circuit you just have to change the flasher relay.. And in the similar thought process I was hoping a component in the warning system could be swapped?
Also... Why wouldn't the led bulbs have the resistors inside as a self contained unit?
LEDs have a much lower resistance than normal bulbs, thats why you get the warning, either solder som eresistors of the correct value inline, or delete the warning circuit. Or take the bulb out lol.
Hmm, higher resistance, not lower, the warning module sees not enough current draw and flags the warning. Google this, OP, and I think you may find some stuff there. I would guess it would involve a parallel resistor across the LED.
Here's a quick Google find for you:
https://sites.google.com/site/1810martin/led-bulbs-and-lights
