Mcdade Posted May 6, 2015 Share Posted May 6, 2015 hey folks, i got a new leather grip from my local toyota dealer and ive had a look to see how i go about replacing it. do i have to cut and re-join the o/d wires or am i missing something on how i get it out. if there is already a thread on how to do this can someone point me in the right direction. cheers Link to comment Share on other sites More sharing options...
Slam Posted May 6, 2015 Share Posted May 6, 2015 hey folks, i got a new leather grip from my local toyota dealer and ive had a look to see how i go about replacing it. do i have to cut and re-join the o/d wires or am i missing something on how i get it out. if there is already a thread on how to do this can someone point me in the right direction. cheers I've been waiting for 2yr for this Link to comment Share on other sites More sharing options...
trebor69 Posted May 6, 2015 Share Posted May 6, 2015 I changed mine a while ago and am sure I didn't cut the wires, all will become apparent when you start to take it apart. Go on, go for it :-) Link to comment Share on other sites More sharing options...
The Raven Posted May 6, 2015 Share Posted May 6, 2015 Cut mine and re joined mine Link to comment Share on other sites More sharing options...
Mcdade Posted May 6, 2015 Author Share Posted May 6, 2015 Cut mine and re joined mine cheers raven, had mine appart already and back together. didnt want to start cutting wires unless i had too but it seems its the only way i think. cheers for the help guys Link to comment Share on other sites More sharing options...
safcdixon Posted May 6, 2015 Share Posted May 6, 2015 The wires slide out of the od button cant remember exactly but i worked this out after i broke mine, its in a small black cradle that the contacts slide in theres a little push clip to press iirc then it slides out, Link to comment Share on other sites More sharing options...
Slam Posted May 6, 2015 Share Posted May 6, 2015 The wires slide out of the od button cant remember exactly but i worked this out after i broke mine, its in a small black cradle that the contacts slide in theres a little push clip to press iirc then it slides out, Sounds more like it... Link to comment Share on other sites More sharing options...
tony tt Posted May 6, 2015 Share Posted May 6, 2015 Toyota fitted my new nob they cut the wires and soldered them up again. Link to comment Share on other sites More sharing options...
Mcdade Posted May 6, 2015 Author Share Posted May 6, 2015 cheers safcdixon, a thought that was the only way tony, al try see if mine will slide out if not am chopping them lol Link to comment Share on other sites More sharing options...
AndyJax Posted May 6, 2015 Share Posted May 6, 2015 Sounds like Toyota took the easy option then.The wires do unclip , but theres lots of clips which keep the wires safe from rubbing on the auto shifter to undo and you have to be careful when routing the wires they don't catch like they did when I did the job.Not something I'd relish doing again. Link to comment Share on other sites More sharing options...
