gordy.r Posted May 2, 2015 Share Posted May 2, 2015 Ok, so I've read a few posts, just want to confirm a few minor details.... I've got Gunk for my engine bay and exhaust, should this be wiped off the engine bay after being put on with a brush, and if so, what's the best method to do so? Polishing - I'm looking at buying a oscillating polishing machine and wondered what's the best polish to use with it (I.e. is there a specific machine polish that should be used over a normal polish that would be put on by hand), and what sequence and or pads should I use from start to finish? I'm not after a pro finish as I've never been one to get into doing detailing myself, normally leave it to the experts, but decided now is the time to learn and have a bash. Thanks in advance for any advice. Link to comment Share on other sites More sharing options...
AlexSavv Posted May 2, 2015 Share Posted May 2, 2015 Hey, Buy a normal MOP, rotary one, not a DA, Get the 3M fast-cut plus compound, and the yellow one that goes with it (ultra fine I think) Then the green cutting pad and the yellow polishing pad Use the green first, put on the car and put some on the pad, slowly and carefully go over the car Yellow second Thanks Alex Link to comment Share on other sites More sharing options...
paulj1 Posted May 2, 2015 Share Posted May 2, 2015 I've got this http://www.cleanyourcar.co.uk/polishing-machines/das-6-dual-action-polisher/das-6-dual-action-polisher/prod_519.html it's spot on for what I need and didn't break the bank Link to comment Share on other sites More sharing options...
The Raven Posted May 2, 2015 Share Posted May 2, 2015 Double post Link to comment Share on other sites More sharing options...
The Raven Posted May 2, 2015 Share Posted May 2, 2015 Hey, Buy a normal MOP, rotary one, not a DA, Get the 3M fast-cut plus compound, and the yellow one that goes with it (ultra fine I think) Then the green cutting pad and the yellow polishing pad Use the green first, put on the car and put some on the pad, slowly and carefully go over the car Yellow second Thanks Alex None DA on his first go? Stuff that, also fast cut plus isnt that a bit harsh for correction? I was using that after i wet sanded mine Link to comment Share on other sites More sharing options...
AlexSavv Posted May 2, 2015 Share Posted May 2, 2015 You're the expert mate, just giving my opinion Link to comment Share on other sites More sharing options...
The Raven Posted May 2, 2015 Share Posted May 2, 2015 You're the expert mate, just giving my opinion im not an expert at all, just concerned that he may take off more than he needs. Stokin or peter richards will be along in shortly to advise Link to comment Share on other sites More sharing options...
AlexSavv Posted May 2, 2015 Share Posted May 2, 2015 Ah yeah fair enough, on a slow setting and carefully, should be fine really Link to comment Share on other sites More sharing options...
L18msy Posted May 2, 2015 Share Posted May 2, 2015 It's silver just wash it it will look the same. I spent a full day cleaning the wife's silver audi and when I finished I stood back and it just looked the same as I started apart from wet looking tyres Link to comment Share on other sites More sharing options...
peter richards Posted May 2, 2015 Share Posted May 2, 2015 hi guys , personally id leave the machine , it will cost you a lot of money with all the other bits youll need , just get some decent clay , polish and a wax you said you wasn't bothered about a pro finish , so just give it a good polish and a wax Link to comment Share on other sites More sharing options...
