Tommyd16 Posted February 17, 2015 Share Posted February 17, 2015 I will be getting and fitting hybrid twins at the end of the month then I want to get an aem fic and bigger injectors so I can run 1.4 bar. What injectors would be suitable? I will hopefully be aiming for 450bhp although I would like 500 lol Link to comment Share on other sites More sharing options...
mattdavies Posted February 17, 2015 Share Posted February 17, 2015 UK Spec 550 maybe but I believe they will require the resistor box. Or something along the lines of a 650cc injector Link to comment Share on other sites More sharing options...
Alex Posted February 17, 2015 Share Posted February 17, 2015 (edited) 1cc per HP is a ROUGH rule of thumb. The 2nd rule of thumb is that you want the maximum duty cycle to be 80%... So if we take 500 as a number. 100 is 20% of that. So 600cc should in theory be enough for 500HP. But you can't get 600's (that I know of). So I would get 650's. Ultimately you don't fit 1000cc injectors because Idle Control gets harder and harder (it's the fine control at the smaller openings that gets harder - but not impossibly so - modern injectors are amazing really). EDIT - I guess if you can ever see yourself going beyond Hybrids and you get a really good quality injector driver / ECU now getting bigger injectors should be fine. It's then down to the mapper to make it all work. The ID1000's seem to be very popular and you could future proof with a fuel system built around them. Edited February 17, 2015 by Alex (see edit history) Link to comment Share on other sites More sharing options...
Ian C Posted February 17, 2015 Share Posted February 17, 2015 I'd get UK spec 550's as they would be easier to map/control and are man enough for the job. The maximum duty cycle percentage is something I feel dates back to ye olde times Bear in mind every BPU Supra out there runs 100% duty once it hits 1bar+ of boost, and not a single injector has ever gone wrong that we've heard of in years. I run mine up to about 95 to 98% right at the top end of boost and revs, and after ten years the only thing not wrong with them was the solenoids Link to comment Share on other sites More sharing options...
Tommyd16 Posted February 17, 2015 Author Share Posted February 17, 2015 Cheers. And I need the resistor pack with uk injectors aswell? Link to comment Share on other sites More sharing options...
Ian C Posted February 18, 2015 Share Posted February 18, 2015 Yes Link to comment Share on other sites More sharing options...
gaijin Posted February 18, 2015 Share Posted February 18, 2015 PE 650cc injectors will drop right in no hassle Have them in my Supra Link to comment Share on other sites More sharing options...
Chris Bailey Posted February 18, 2015 Share Posted February 18, 2015 650cc drop ins would be my choice, gives you a little headroom for more power in the future if you choose to go down the single turbo route. Link to comment Share on other sites More sharing options...
Ian C Posted February 19, 2015 Share Posted February 19, 2015 Yep those are fine too. Link to comment Share on other sites More sharing options...
Wez Posted February 19, 2015 Share Posted February 19, 2015 Another +1 for the PE 650cc, no resistor pack needed and if going piggyback they are not to big to allow nice control Link to comment Share on other sites More sharing options...
Tommyd16 Posted February 19, 2015 Author Share Posted February 19, 2015 Where can I buy these? Link to comment Share on other sites More sharing options...
Wez Posted February 19, 2015 Share Posted February 19, 2015 Could try Whifbitz, SRD or MVP, I imagine one of the registered traders can source them for you. Link to comment Share on other sites More sharing options...
