emanage ultimate base map
jawan
 Share
If your daft enough to fit injectors without being able to input the correct values in the global injector adjustment, you shouldn't be fitting the EMU or the injectors yourself, and taking it to someone who can.;)
It was more a case of clarification for any members reading the above comments thinking they can stick huge injectors in along with their turbo kit and run on the stock ECU/map to drive to their tuners.
You may think it daft but I've read about it being done on here before now.
 Share
