2JZ and 1Jz head
Jellybean
Supraforums has more information regarding this, it is worth a search there, I was looking into 1jz's a couple of weeks ago and someone over there did actually do a flow comparison between a 1jz and 2jz head, the 2jz flowed better. As for response I couldn't tell you unfortunately. Good luck with your search!
Both these Yamaha developed heads flow superbly, i would use whatever is in the best condition, a lot are in need of valve guides these days and there lie demons.
thanks Chris!
The plan was to overhaul the 1Jz head and just swap over when needed , VSS are 21 years old on mine now :) Still going strong so not touching anything
Just doing my research if it is a good idea , rather than waiting till I need to do it
One of the pros of the 1jz is response over the 2jz from what I am told
