Bally Posted August 6, 2014 Share Posted August 6, 2014 Hi all Got couple of small oil leaks on 95 TT auto import anyone know of common problems regarding oil leaks just want to narrow it down then get it sorted Grateful for All answers Link to comment Share on other sites More sharing options...
Scooter Posted August 6, 2014 Share Posted August 6, 2014 Common ones...... Cam cover seals, usually at the rear turbo side and leaks down the back of the engine on to the gearbox housing Oil pressure sensor, not so common and tends to get worse quickly - this is behind the aircon compressor Front crank seal, if it's just weeping (you said yours were small leaks) this will coat the oil sump... Where can you see the oil? Link to comment Share on other sites More sharing options...
listy Posted August 6, 2014 Share Posted August 6, 2014 Best bet is to clean as much of it off as you can, then go for a short drive (get it up to temp) then get it up in the air, and look for the leaks. Link to comment Share on other sites More sharing options...
Bally Posted August 6, 2014 Author Share Posted August 6, 2014 Thanks for the info oil is dripping off the sump I need to clean it down al have a good luck thanks again pal Common ones...... Cam cover seals, usually at the rear turbo side and leaks down the back of the engine on to the gearbox housing Oil pressure sensor, not so common and tends to get worse quickly - this is behind the aircon compressor Front crank seal, if it's just weeping (you said yours were small leaks) this will coat the oil sump... Where can you see the oil? Link to comment Share on other sites More sharing options...
listy Posted August 6, 2014 Share Posted August 6, 2014 If it's dripping off the sump, either the sump seals have gone, or more likely, the front crank seal has gone. When you drive, the oil leaks from the FCS and gets pulled under the sump. Have a look at the very front bottom of the engine, and see if there is oil there. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 7, 2014 Share Posted August 7, 2014 You need to clean the whole engine and, as Listy said, go for a drive and see whats leaking. Just because its dripping off the sump doesn't mean it hasn't dripped from somewhere higher up. Link to comment Share on other sites More sharing options...
Bally Posted August 7, 2014 Author Share Posted August 7, 2014 Thanks everyone for replies it is in the garage Monday for timing belt I will ask them to have a quick look on their ramp Link to comment Share on other sites More sharing options...
