GSR2007 Posted February 19, 2014 Share Posted February 19, 2014 Hows things folks recently bought a tt supra with a w58 box I know these are the weakest manual box available but until funds allow for an upgrade it will have to do, car only has a fmic,hks ssqv,apexi filter and cat back exhaust, I would like some info where to go from here as regards uping the power without killing my gearbox? and how do I fair out mapping wise can I just use a emanage or what is recommended? all info would be great thanks in advance Link to comment Share on other sites More sharing options...
listy Posted February 19, 2014 Share Posted February 19, 2014 I have an NA-TT on a W58 box, at BPU but set to 1 bar. Has held out for me for the last 2 years no problem. Link to comment Share on other sites More sharing options...
James Posted February 19, 2014 Share Posted February 19, 2014 You could BPU it (click the blue link which has appeared when 'BPU' is typed to see the parts list required) However, the W58 will be at it's upper limit when putting that much torque through it so it may not last. It might last you ages without issue at all, but yet again it could fail very quickly. My first Supra was a W58 NA-TT with about 360bhp and it was my daily driver for 4 years without issue, until the clutch went. Gearbox was still ok though. The only thing it didn't have compared with BPU was a first decat (downpipe). I was always nervous to fit one (I did buy one, just never actually fitted it!) just in case it caused the box to fail. *EDIT* The hyperlink doesn't appear to be working, so here is the thread you want to read: http://www.mkivsupra.net/vbb/showthread.php?94705-BPU-(Basic-Performance-Upgrade) Link to comment Share on other sites More sharing options...
GSR2007 Posted February 19, 2014 Author Share Posted February 19, 2014 I have an NA-TT on a W58 box, at BPU but set to 1 bar. Has held out for me for the last 2 years no problem. what sort of power and torque is that leaving you running?? sorry im a bit clueless to modding these cars if im honest Link to comment Share on other sites More sharing options...
MK2 Posted February 19, 2014 Share Posted February 19, 2014 I would recommend at least a r154 box, as the w58 won't hold bpu (400rwhp). Seen them broken several times under 18psi of boost. Not sure what boost you're running, but I would leave it at around 14-15psi until you have a better box. Any piggyback will be fine. Personally I would go with a map-ecu, however people are getting great results with the emanage aswell. Link to comment Share on other sites More sharing options...
GSR2007 Posted February 20, 2014 Author Share Posted February 20, 2014 Thanks for the advice folks can anyone tell me what changes are involved to switch to r154 and what car they come in?? Link to comment Share on other sites More sharing options...
MK2 Posted February 20, 2014 Share Posted February 20, 2014 You can find the r154 in the turbo MKIII Supras. To do the swap you'll need the following from the top of my head. 1JZ bellhousing and flywheel shifter extension r154 clutch kit r154 driveshaft (front half only) Link to comment Share on other sites More sharing options...
GSR2007 Posted February 20, 2014 Author Share Posted February 20, 2014 You can find the r154 in the turbo MKIII Supras. To do the swap you'll need the following from the top of my head. 1JZ bellhousing and flywheel shifter extension r154 clutch kit r154 driveshaft (front half only) Thanks for the help one last query when you say 1jz belhousing and flywheel is it from 1jz in the mk3 supra or the one that comes in the jzx100 chasers?? I may aswel gather these bits first think it would make the most sense then modify a bit would love to see 450-500hp safely Link to comment Share on other sites More sharing options...
Noz Posted February 20, 2014 Share Posted February 20, 2014 1jz flywheel will fit 1jz engine regardless of its chassis code. Your need r154 slave cylinder and a chaser cross member. Some w58 can handle mental power. Mine has handled 417bhp for AGES and when the torque or power kicks in, its fine. I blew it up smashing it into second from the red line. They don't like abuse or slicks. Your need an R154 if you do anything above 400. Link to comment Share on other sites More sharing options...
GSR2007 Posted February 20, 2014 Author Share Posted February 20, 2014 1jz flywheel will fit 1jz engine regardless of its chassis code. Your need r154 slave cylinder and a chaser cross member. Some w58 can handle mental power. Mine has handled 417bhp for AGES and when the torque or power kicks in, its fine. I blew it up smashing it into second from the red line. They don't like abuse or slicks. Your need an R154 if you do anything above 400. Thanks for all the info folks Link to comment Share on other sites More sharing options...
