Stevo Posted January 28, 2014 Share Posted January 28, 2014 Hi guys I need to buy a new clutch release bearing and pilot bearing from Toyota but they aren't listed under those names. Can anyone confirm the following: Pilot bearing = 'Bearing (for input shaft) 90363-12002 Release bearing = 'Bearing assembly, clutch release 31230-22100 Should add they are for a 5 speed NA Cheers Link to comment Share on other sites More sharing options...
hodge Posted January 28, 2014 Share Posted January 28, 2014 I've got a spare pilot bearing if you want it. Link to comment Share on other sites More sharing options...
Stevo Posted January 28, 2014 Author Share Posted January 28, 2014 Cheers. Is it new and off an NA like? Not sure if the TT and NA ones are the same. Link to comment Share on other sites More sharing options...
rider Posted January 28, 2014 Share Posted January 28, 2014 Hi guys I need to buy a new clutch release bearing and pilot bearing from Toyota but they aren't listed under those names. Can anyone confirm the following: Pilot bearing = 'Bearing (for input shaft) 90363-12002 Release bearing = 'Bearing assembly, clutch release 31230-22100 Should add they are for a 5 speed NA Cheers You may be able to confirm your part numbers off this site link http://www.toyodiy.com/parts/g_J_1993_TOYOTA_SUPRA_JZA80-ALFQZ_2.html Link to comment Share on other sites More sharing options...
Stevo Posted January 28, 2014 Author Share Posted January 28, 2014 You may be able to confirm your part numbers off this site link http://www.toyodiy.com/parts/g_J_1993_TOYOTA_SUPRA_JZA80-ALFQZ_2.html That's where I got them from mate. What I was after is confirmation that the pilot and release bearing are actually described as listed above. Thanks anyway, but I'm pretty certain I've got them right. Link to comment Share on other sites More sharing options...
Graham1984 Posted January 28, 2014 Share Posted January 28, 2014 Ask Nic he seems to be the resident part number encyclopedia. Link to comment Share on other sites More sharing options...
hodge Posted January 29, 2014 Share Posted January 29, 2014 Cheers. Is it new and off an NA like? Not sure if the TT and NA ones are the same. It's brand new. Link to comment Share on other sites More sharing options...
Stevo Posted January 29, 2014 Author Share Posted January 29, 2014 Mint - cheers mate I'll give it a try. Just need to get the old one out now! Link to comment Share on other sites More sharing options...
hodge Posted January 30, 2014 Share Posted January 30, 2014 Mint - cheers mate I'll give it a try. Just need to get the old one out now! There's the hard part, good luck. There's a YouTube guide to do it. Try searching "removing spigot bearing". Link to comment Share on other sites More sharing options...
