Rough running gearbox down on power.
mac79
1994 TT turbo no mods.
I have been noticed that when the car is in drive I am starting to get quite a bit of vibration when in drive and stationary. If I put it into park its fine.
I have also noticed that I seem to be down on power everything it boosting right and the gauge is reading 0.7.
It seemed to accelerate a lot quicker before.
Any ideas on what it could be or where to start looking.
Or even better somewhere to take it for them to have a look I am based in Wolverhampton.
Engine running? Also if youre down on power and its a bit rough Id say it sound like a weak spark somewhere, check all the coil clips and parks.
It was done with the engine running.
The clips were changed about 6 weeks ago and it has just had a new set of plugs.
Is there a way to check the coil packs?
I have reset the ecu, boost and power is back but still the little niggle vibration througth the steering and gear stick.
The only thing thats different was i have had the belt changed at service so maybe it needs adjusting?
