Guest aspire Posted April 29, 2013 Share Posted April 29, 2013 i have one of these fitted, but as i start a build want to keep 2 sensors for after market gauges is their another way instead of using this sandwhich plate? Link to comment Share on other sites More sharing options...
Marco79 Posted April 29, 2013 Share Posted April 29, 2013 What other sensors do you want mate? Are you just on about oil temp and preassure? Link to comment Share on other sites More sharing options...
Noz Posted April 29, 2013 Share Posted April 29, 2013 Most adapter plates come with 4 inputs. Link to comment Share on other sites More sharing options...
Guest aspire Posted April 29, 2013 Share Posted April 29, 2013 What other sensors do you want mate? Are you just on about oil temp and preassure? yes Link to comment Share on other sites More sharing options...
Kaan W Posted April 29, 2013 Share Posted April 29, 2013 Cant you use the sandwich plate for an oil cooler? Link to comment Share on other sites More sharing options...
Guest aspire Posted April 29, 2013 Share Posted April 29, 2013 I JUST WANT THE SANDWHICH PLATE GONE,, sorry, big letters! but i want to keep my sensors as marco says Link to comment Share on other sites More sharing options...
Marco79 Posted April 29, 2013 Share Posted April 29, 2013 I JUST WANT THE SANDWHICH PLATE GONE,, sorry, big letters! but i want to keep my sensors as marco says So you want your sandwich plate ....... I'm sure there are other locations you can tap into, I'm just going to use a sandwich plate tho bud. Link to comment Share on other sites More sharing options...
sideexitsupra Posted April 29, 2013 Share Posted April 29, 2013 Cant you use the sandwich plate for an oil cooler? Yes I have one for my oil cooler. Link to comment Share on other sites More sharing options...
bignum Posted April 29, 2013 Share Posted April 29, 2013 This is a tech section guys:flasher:sump for temp, lexus bolt mod for pressure. Link to comment Share on other sites More sharing options...
Noz Posted April 29, 2013 Share Posted April 29, 2013 Unless you drill sensor bung's into somewhere that the oil travels your going to find it hard to remove the oil filter plate. Link to comment Share on other sites More sharing options...
Marco79 Posted April 29, 2013 Share Posted April 29, 2013 This is a tech section guys:flasher:sump for temp, lexus bolt mod for pressure. Bolt mod will already be done as he is going NA/T so that's an easy fix sump could be easily done aswell Link to comment Share on other sites More sharing options...
