Recommended Brake Fluid MR2
Hobgoblin
 Share
I dont know! I only use DOT 4 at work ;)
Castrol SRF for the win with a 320 C dry boiling point and 270 C wet boiling point, but its very expensive at £50 a litre
You could use a special DOT 4 that has a higher dry and wet boiling point
than normal DOT4
Normal DOT 4 (265 C dry and 160 C wet)
Special DOT 4 (312 C dry and 216 C wet) Motul RBF600 Factory line is a higher spec DOT4, i use this in my car.
There is also Motul RBF660 which has 325 C dry and 204 C
wet boiling point and is approx the same cost as Castrol SRF
When was your brake fluid last changed ?
Its hydroscopic so absorbs moisture which massively lowers its
boiling point.
I'd do a full vacuum flush and give the RBF 600 a try as its half
the price of the SRF, i didn't have any issues with this at Silverstone
on my last track day but it was fresh fluid.
 Share
