Does the low beam light up during the main beam flash?
Ark
 Share
Hello,
Odd question perhaps, but when you flash the main beam, which bulbs are supposed to come on? The main ones obviously, but does the low beam come on too? Somehow I'd swear I've got a crossed wire because only the low beam lights up with the flasher...
Thanks
It was a general question, because I believe the MOT says the dipped beam has to stay on when you flash the main beam - at least if you have HIDs it does. My dipped beam on the Honda flashes with the main beam (if it was off before) and I couldn't remember if the Supra did the same, obviously it's not supposed to from the replies so thought I'd ask if the dipped stays on when you flash mains (if it was on before).
When you say "both beams flash" surely you mean the dipped beam just stays as it is? i.e. on, if it flashed as well, you'd have two beams per headlight. Whereas some cars have a combined beam and dipped main light, with two filaments in one bulb, or that may be old fashioned now.
The Soarer and Aristo both have one bulb for dip and another bulb for main (the Soare has separate light units). With the lights off, the flasher illuminates both dip and main beams.
If it's a JDM thing, perhaps the J-spec Supra is the same?
I'd owned the Soarer for 4 or 5 years before I noticed. In daylight you can't see the beams, and at night dip is on anyway.
Edited by garethr (see edit history)
OK, for the benefit of everyone who is desperate to know the resolution to this topic:
1: The main beam only illuminates at the SAME TIME as the low beam, regardless of whether you are using the flasher or permanent-on switch.
2: My bodge-o-rama of wiring is fine; it was the el-cheapo fuse holder in my Chinese HID kit that is failing because it isn't weather proof. I gave it a good jiggling about and it started working again...for now. Need to order something like this to replace it:
http://www.demon-tweeks.co.uk/performance/fuse-relay-boxes/auto-marine-splash-proof-fuse-holder
3:
Impressive!
Is that Martin, hiding behind a new identity? Thanks for the helpful comment you cheeky young scamp. How the devil are you?
Edited by Ark (see edit history)
 Share
