Swampy442 Posted September 15, 2012 Share Posted September 15, 2012 Can 1J cams be fited to a 2J head? Also Ive found some Crower 272 cams at a good price, specs are :- Duration: 272 int / 272 exh Valve lift: 9.52mm int / 9.65mm exh Would they require shimming, or would it be a fit and see thing? Cheers. Link to comment Share on other sites More sharing options...
HadeS Posted September 15, 2012 Share Posted September 15, 2012 There is some work needed to fit 2jz cams (I have seen some info on the internet) Don't know about shimming though. Link to comment Share on other sites More sharing options...
Swampy442 Posted September 15, 2012 Author Share Posted September 15, 2012 I want to put 1JZ cams in a 2JZ, does the same apply? Link to comment Share on other sites More sharing options...
HadeS Posted September 15, 2012 Share Posted September 15, 2012 If you have to do little work (grinding) to 2JZ cams to fit in to 1JZ then I presume no work is required to the other way round. Link to comment Share on other sites More sharing options...
mattdavies Posted September 15, 2012 Share Posted September 15, 2012 using this thread http://www.supraforums.com/forum/showthread.php?379822-Fitting-US-jza80-2jz-gte-cams-into-1jz-gte i would say use 1jz cam seals and a bit of lathe work and you'll be away Link to comment Share on other sites More sharing options...
Swampy442 Posted September 15, 2012 Author Share Posted September 15, 2012 Screw that then, Ill just get 2JZ ones. Link to comment Share on other sites More sharing options...
HadeS Posted September 15, 2012 Share Posted September 15, 2012 There is couple of us running 1JZ, maybe you will share the good price cams? Link to comment Share on other sites More sharing options...
mattdavies Posted September 15, 2012 Share Posted September 15, 2012 i believe they are on a popular auction site Link to comment Share on other sites More sharing options...
Swampy442 Posted September 16, 2012 Author Share Posted September 16, 2012 They are indeed on eBay Link to comment Share on other sites More sharing options...
