Rattling o/s/r
Jonnybravo2667
Hi everyone i have a problem with my o/s/r wheel rattling, symptoms are a rattle when that wheel hits a pothole and also i tested the wheel for play on the bearing. There no play if i hold the wheel at either side but there movement if i hold it at top and bottom, any ideas?
Thanks for any replies
  • 2 months later...
I had the exact same probs mate turned out to be the inside bushes on the upper suspension arm were shagged
ended up getting urethane bushes pressed in as a new wishbone was a ridiculous price
If you have movement on the wheel holding it top to bottom then there's a
good chance you have wear in the upper or lower arm bushes or ball joints.
This might not be your noise though so as suggested get it on a ramp asap
and do as Nic suggests first.
