ashbuster Posted May 30, 2012 Share Posted May 30, 2012 (edited) lol http://en.wikipedia.org/wiki/Oxygen_sensor saves explaining Edited May 30, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted May 30, 2012 Share Posted May 30, 2012 hi emperor, I agree its not the boost lines. i followed the vvti diagram for the vacumm lines and If im correct in saying you only blank vacumm lines if you are adding a boost controller due to you trick the ecu ? I didn't put boost controller yet, so everything is stock with me. i did take the first cat off and still done the same. is the oxygen sensor - that comes after the turbos into the little section of the exhaust before the cat ? or is that the lamber sensor ? Oxygen sensor and Lambda are one and same thing... yes the sensor right after the turbos. Check for the part number. VVTI Vacumm diagram - it was one of yourt posts emperor. It show the 1994 GTE engine and also VVTI GTE engine http://mkivsupra.net/vbb/showthread.php?250370-Can-anyone-tell-me-where-do-these-vacuum-lines-go&highlight=vvti+air+pipes Those vacuum lines are not connected on the VVTi engine. Just the support is one and same for nonVVTi and VVTi engines. Link to comment Share on other sites More sharing options...
SpeedyAndy Posted May 30, 2012 Share Posted May 30, 2012 I didn't put boost controller yet, so everything is stock with me. Oxygen sensor and Lambda are one and same thing... yes the sensor right after the turbos. Check for the part number. Those vacuum lines are not connected on the VVTi engine. Just the support is one and same for nonVVTi and VVTi engines. Yes wewsupra engine is stock aswell - the only thing that is different is the air induction. wewsupra as a apexi filter and hard pipe instead of the standard vvti air box. Yes i thought so, just double checking regarding the oxygen sensor Well i follow where all the air pipes should go using this diagram to put back the boost pipes that was blanked off for the boost controller so they are back to stock - how they should be with out a turbo controller. I Link to comment Share on other sites More sharing options...
EMPEROR Posted May 30, 2012 Share Posted May 30, 2012 Just check the oxygen sensor part number when you have time. I am beginning to think I'm using the wrong one. Did yours come with the engine? Link to comment Share on other sites More sharing options...
SpeedyAndy Posted May 30, 2012 Share Posted May 30, 2012 Yes mate. It came with the engine. Link to comment Share on other sites More sharing options...
spikedjack Posted May 30, 2012 Share Posted May 30, 2012 You're missing the point Andy, there are 4 vac lines not connected that are blanked off that haven't been re connected. If you want to test the housing for the maf then I can bring my filter setup for mine and test that on the car to eliminate any issues. Something is amiss somewhere that hasnt been seen. Me and other Andy will come and look at it tonight and see what's up. May even be able to relay some stuff to you lacho on facebook later and see if between us we can sort it Link to comment Share on other sites More sharing options...
SpeedyAndy Posted May 30, 2012 Share Posted May 30, 2012 (edited) OK then... yes bring your filter set up - that will eliminate the maf issues. Edited May 30, 2012 by SpeedyAndy (see edit history) Link to comment Share on other sites More sharing options...
wewsupra Posted May 30, 2012 Author Share Posted May 30, 2012 thanks jack for your help and time and anyone else who has helped or gave advice lets see what tonight brings Link to comment Share on other sites More sharing options...
Westy Posted May 30, 2012 Share Posted May 30, 2012 Took some pics quickly for you mate...is this what your after or somewhere else!? Link to comment Share on other sites More sharing options...
ashbuster Posted May 30, 2012 Share Posted May 30, 2012 i think hes looking for underneath mate by the front where you block off for a boost controller (front turbo) Link to comment Share on other sites More sharing options...
wewsupra Posted May 30, 2012 Author Share Posted May 30, 2012 right fast update until jack or andy can explain better jack came to mine tonight and we used his hks hard pipe with the proper maf fitting and inside pipe work was plastic bits pointing the air flow down and guess what lol engine is running ok now 2nd turbo is kicking in and im reving over 5k ect only problem i got now is car has very very slight idel problem the 2nd lamber sensor is not plugged so i think we going to try that this week as well. or i have a small air leak somwhere Link to comment Share on other sites More sharing options...
trinitom Posted May 30, 2012 Share Posted May 30, 2012 glad you got it, are the revs going low or high? Link to comment Share on other sites More sharing options...
spikedjack Posted May 30, 2012 Share Posted May 30, 2012 running fine minus a slight idle issue. i would be good money on that being down to one of those vac hoses inlet side though rich. sort out the charcoal canister piping too Link to comment Share on other sites More sharing options...
wewsupra Posted May 30, 2012 Author Share Posted May 30, 2012 thanks jack mate if any one seachs this in future u need proper maf pipe end of lol Link to comment Share on other sites More sharing options...
SpeedyAndy Posted May 31, 2012 Share Posted May 31, 2012 yeah jack, i will down on friday night and saturday sorting every thing out. I'm glad we got to the issue which was the MAF. Emperor - check your maf isn't playing up mate, as this has played a big part of wewsupra car. With the ideling issue - its abit lumpy. There is a lamba sensor under the car that fits in to the old cat - 1994 engine version. Does this need to be in the exhaust on the VVTI as i do beleive on the vvti there is a lamba sensor after the turbo's but before the cat ? Link to comment Share on other sites More sharing options...
EMPEROR Posted May 31, 2012 Share Posted May 31, 2012 (edited) VVTi engine has only 1 oxygen sensor right after the turbos, before the first cat. So the idle problem is not because of the 2nd oxygen sensor not connected. I guess you'll have to clean the throttle valve out of oil and adapt the TPS to the ECU again, as it didn't have battery for some time and most probably lost the settings. Edited May 31, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
wewsupra Posted May 31, 2012 Author Share Posted May 31, 2012 ive got to find a induction kit for the vvti as most are 350 pound plus more Link to comment Share on other sites More sharing options...
ray007 Posted August 26, 2012 Share Posted August 26, 2012 I think I have a similar problem, might sound silly but check all your earths Link to comment Share on other sites More sharing options...
