Dragonball Posted August 5, 2005 Share Posted August 5, 2005 Do stage III hybrids have enlarged wastegates? else you might as well put a dead rat up your exhaust... The wastegate may be enlarged slightly- and a new 'button flap' fitted - gets another 8 mm approx on diameter (from memory) Also depends on the quality of the turbo being 'hybrided' as have see a one that had mini cracks around the wastegate hole - and could not be done This was done on both Heckler's and Ash's hybrids - which now have a few good miles on them Link to comment Share on other sites More sharing options...
Ian C Posted August 5, 2005 Share Posted August 5, 2005 A lot of the turbos I've seen have had a crack at the wastegate - it precludes any machining work, as Paul says, but doesn't mean the turbo is buggered. In fact I can't recall hearing of one going wrong because of this crack - must be a design phenomenon or something. -Ian Link to comment Share on other sites More sharing options...
MONKEYmark Posted August 5, 2005 Share Posted August 5, 2005 i used to get as high as 1050 degree on my egt gauge, since i had a walbro fuel pump fitted dont see above 850. no fuel comp and still on stock 440cc injectors also in ttc mode the egt`s would be higher too Link to comment Share on other sites More sharing options...
JohnA Posted August 5, 2005 Share Posted August 5, 2005 Mark, do you know what AFRs you had during the 1050 vs 850 degree runs? I take it that boost was at similar levels in both cases, right? Link to comment Share on other sites More sharing options...
