single digit 1/4 mile time
Lacee
hope we will run a single digit time on Sunday here in Hungary. Give us a finger cross.... for the good time
we are working hard on the car now, i know it's an A70 supra but runin with a fully build 2jz, with GT47-88.
2012-04-18-330.jpg the old rear subframe
was hoping for a better pic than that...
working on the rear suspension and subframe, just installing the A1 arms, alu bushings, and spacer for the wheels.
i will upload more pics tomorrow, now a bit tired, sorry.
need pics of the whole car mate! sounds like abit of a beast if your hoping for single digit quaters :cool:
what kind of pics do you want???
here is the engine bay:
one more: PICT0007.jpg
the whole car in the garage tonight waiting for the suspension alignment:
got a full spec on that?
Spec:
3.0 liter 2jz-gte block
carrillo rods
Cp pistons
Pro gramm main caps
ARP main studs
ARP L19 head stud
stock GTE head gasket
virtual works header T6
GT47-18 turbo
2200 ccm ID injectors
Aeromotive PRO pump, with AN12 feed line
custom fuel rail
custom intake plenum, with Q45 TB
super spark coils with HKS DLI
6 speed getrag trans
3 plate carbon tilton clutch
custom drive shaft
VEMS ECU
we are running with 10x26x15 M&H racemaster
Good luck with it :)
Would be good if you could stick a 28" ET Drag under there, guarantee you a low 9 high 8 with your power.
It's hard work with the tyre you have but I'm sure you'll get there in the end.
You are right mate, we was fighting all day with the traction, runing mid 11.
But at the end of the day we found it and started with a 10.5 and a 10.1 and a final 9.6@241... :D:D:D:D i was so happy, with still only 2.1bar, and the car still over 1300kgs.
i will upload pics and videos, still working on it...
here is the time slip:
and the car in the burnout box:526269_364020986982333_142755575775543_1108774_36724111_n.jpg
:D
Congrats bud!! Awesome time in the conditions!
I think it's gonna be tough to put more power through those tyres though...
Sean @ Titan fit some 28"s under his mk3 so it is def possible.
You've still got around 20mph on that turbo to play with and your 60 will drop on the 28's.
Try it out if you can, you won't regret it and should be a giftwrapped 8 for you with your weight and power :)
  • 2 weeks later...
