Doorcards, 2nd Cat(for MOT), 6 speed shifter mechanism, plus much more
marc_p
Hi Guy's, fairly simple, I need the following parts:
OEM Parts:
-Pair of doorcards in very good condition.
-2nd Cat(needed to get car through MOT).
-Pre-facelift(V160) shifter, the V161 sits too high for my liking.
-Interior door handle surrounds(both sides).
-Plastic sill trim in very good condition.
-6 speed selector seal
-v160/v161 gearbox oil
Aftermarket Parts (getting these anyway so thoughI'd do a quick shout to see if theres any used parts before I buy them new)
-Top Secret rear diffuser
-Ridox side skirts (w/carbon lip)
-Twin electric fans with shroud, termostat and wiring
Do you need the doorcards as replacements or are you after a pair to re-cover?
I've got a pair but they have a couple of nicks and the material has bubbled a bit on the passenger side. I've got some others that I was going to use while I refurbished them but if your need is greater than mine.....
Replacements at the moment, mine have aftermarket speakers in them and I want them back to OEM style.
Thanks anyway :).
I've got a pair of door cards' date=' unfortunately they have a 42mm hole for tweeters in, have the handle surrounds too if you still need them[/quote']
Got the handle surrouds already, where are the tweeters located in the doorcard as I might be putting some in but will have to check the size of mine?
  • 2 weeks later...
