Slam Posted January 16, 2012 Share Posted January 16, 2012 Hi all,i have picked up a Toyota® (the R is in a circle ) D Limiter today(2nd hand) Dose anyone kno about this model It came out of a working car. On the label is wire info which will follow. I need as much info as poss pls. RED-12v Live Black-Earth(i thought this was more green & blue [GRIN][/GRIN]) Yellow-KPH IN Green-MPH OUT In the picture you can see a blue wire coming of the green wire(mph out) it the go's to a female connector with a red wire coming out to a female connector. Now i suffer from BAD electrical GREMLINS [ANGRY][/ANGRY], so Wylie e will fit(Thanks) Need to kno wots going on with the green into blue into red Hope you can see pic's ok.[ATTACH=CONFIG]144536[ Link to comment Share on other sites More sharing options...
Slam Posted January 16, 2012 Author Share Posted January 16, 2012 Bumpy bump Link to comment Share on other sites More sharing options...
wile e coyote Posted January 16, 2012 Share Posted January 16, 2012 What we want to know guys is which wires do i need to attach to this behind the dash. The car its going in is an na auto Thanks Darren Link to comment Share on other sites More sharing options...
wile e coyote Posted January 17, 2012 Share Posted January 17, 2012 You may have to ask brendan which wires it was attached to Link to comment Share on other sites More sharing options...
Slam Posted January 18, 2012 Author Share Posted January 18, 2012 Dose anyone want to have a sot at this Link to comment Share on other sites More sharing options...
barneybrendan Posted January 18, 2012 Share Posted January 18, 2012 sadly i didnt take any pics and my clocks are gone .the loom has gone aswell so i cant double check. Link to comment Share on other sites More sharing options...
wile e coyote Posted January 18, 2012 Share Posted January 18, 2012 bugger Link to comment Share on other sites More sharing options...
stevie_b Posted January 18, 2012 Share Posted January 18, 2012 I've got no experience of that model but I'd put money on that it's ghot nothing to do with Toyota themselves. It looks like a cheap converter that will over-assist your power steering. I would use the wiring diagram here as a reference: http://homepage.ntlworld.com/peter.betts/supra/TechTips/dsc_speedo_mph.jpg So, splice the red wire into pin 4 of the speedo connector (C13). Connect the black wire to any convenient earth point or wire: the diagram doesn't specify a particular connection. Cut the wire going into pin 5, leaving at least 3 or 4 inches on the connector side. Join the yellow wire to the loom side of the wire you just cut. Join the green wire to the connector side of the wire you just cut. Job done. Don't worry about the daisy-chained wires on the end of the green: it looks like someone wanted to extend that wire, and used whatever colours they had in the bottom of their toolbox. You're lucky they didn't have tartan and baby-pink instead as that's what they would have probably used . Remove the extensions if you want. Link to comment Share on other sites More sharing options...
Slam Posted January 18, 2012 Author Share Posted January 18, 2012 Now what did i say about the GREMLINS, they out already,totaly lost me mate,but will see if wile e coyote will make sense. thanks for the info though. Link to comment Share on other sites More sharing options...
wile e coyote Posted January 18, 2012 Share Posted January 18, 2012 Cool thanks mate will get that done for my little bro now Link to comment Share on other sites More sharing options...
wile e coyote Posted January 21, 2012 Share Posted January 21, 2012 Ok guys got this fitted today for my bro, pic perfect worked treat thanks Link to comment Share on other sites More sharing options...
Slam Posted January 22, 2012 Author Share Posted January 22, 2012 All is good,converted & de-limited,thanks bro,& Barney. Link to comment Share on other sites More sharing options...
