Water/Meth with EMU
Noz
Hi guys,
was just interested if anyone had seen or used water/meth with ulitmate e manage before. hoping to collect my booster NA next week, and would like to reduce changes of det, if i gain anything power wise its a bonus, but mainly want it for water injection.
Ricky will know more than me, he's actually done it :) I never quite got around to that particular bit of tinkering.
Daft question, but would a fuel injector risk corroding up if you ran water through it?
I guess it might, however i was always under the impression that injector internals where made from stainless?
I remember years ago when i was into tuning mechanical injection VW engines, a company came up with the idea of using a electronic fuel injector for adding extra fueling, so i wondered if the injector idea would work, given that if still available, the high speed valves that Aquamist used to sell where well over £100 a shot.
here is a list of the kit im considering buying:
it has tank.pump,wirring,new plastic line,nozzle and pressure activated switch which is adjustable
any thoughts?
With the pressure operated system you have no fine control of WI, its just done by activation pressure and size of jet, adequate if your just looking for a bit of insurance when on boost, and help with in cylinder cooling, but not any good for optimum power, as you really need to be more precise with amounts and point of injection in the load range. you cant integrate the pressure operated kit with the EMU.
What kit is it, and what make?
Edited by Tricky-Ricky (see edit history)
this could still be very useful though, as if i reduce the chances of det i can increase the boost slightly rather that use the octane in the meth?
Just run a mix of 50/50 water and meth, you wont see anything from the meth, unless you run 100% but ideally its needs mapping for, but 50/50 is the best of both worlds:)
