veilside arches/spacers
Guest Rsand85
The size of spacer required would depend on what size wheels you had, width and offset.
There are also at least 2 different sizes of overfender
Mine came from Ibrar(Speedwells) and I used 25mm spacers all round, but the rears could do with being more for my liking
I have 275's with a different offset on mine as i bought the wheels to fit the arches. I have 15mm spacers on the back and none on the front :)
The only way to do this correctly is to take your current tire spec, wheel size, plus the size of the arch extensions (i.e. the outward displacement distance in mm's from the original body panel location) and then work it all out?
What's the displacement measurement of the arches - let's start there?
EDIT: Why not throw in your current wheel dimensions and tire sizes too?
Edited by SupraAyf (see edit history)
As others have said, get arches, then measure is easiest method.
Place up arch against car, measure out from outside wall of the tyre to inside of the veilside arch - thats how big your spacer would need to be with your current rims.
Guest Rsand85
Sorry should have really said its 19" mania vortex wheels cant remember the offsets. I was just being lazy really thought somebody mite have known without me having to dig the wheels out of the spare room!.Judging by eye i would say fronts need nothing to very little the rears are a bit scary tho without a measurement would say 100mm would be a good start!Will get the wheels on at weekend to see tho.i didn't know there were different width arches cheers for the help though.
Yep, good idea. Get the wheels on and lets all have a look at the wheel alignement with the arches. Regarding your 100mm comment, I don't think you will be pushing over the 50mm spacer requirement in all honesty.
Guest Rsand85
true heard that one a few times in the past usually when ive made an epic mistake!!will get a rim on tonight and see what the script is cheers
