Another supra with boost problems
-Welsh-Stealth-
It seems like I have a bit of q boost leak. I noticed 2 days ago that I was only making 0.3 bar boost when the car was mapped at 8.5 psi or 0.48bar boost. After realising this I tested the boost to see what the AFR was reading. Thinking it way just be a fault boost gauge.Again it was mapped at 11 AFR and now it's goin straight to 10 AFR which is the lowest my gauge reads. On top of that it seems like it's slipping into det :( I have recently replaced the stock fuel pump for the walbro, so the car was mapped with the stock pump. Also running stock NA injectors. The dizzy rotor arm and plugs (iridium grade 7) were replaced in august with the na-t build. And the ignition leads (after market)were kept the same...however these have been on the car since ownership in may 09.
My thoughts are on the ignition leads being quite old and needing replacing. With lack of spark or poor spark burning off less fuel(10afr) and causing what seems like det?!
I'm having a look friday/Saturday to try source the problem. But I just thought I'd see if anybody could offer up some expert advise before I get stuck in this weekend....also off boost it seems fine AFR and driving wise.
All help appreciated :)
Lewis
Heat wrap probably makes it worse. I have said for years that turbos, wastegates and exhaust systems hung off tubular manifolds need fully supporting which is an art in itself, and one even the might of Ford and Porsche struggled with. Ford had several revisals of their friction damping plate for the Cosworth Sierra, and Porsche went through hoops with the early 944 turbo cars cracking manifolds. I have yet to see an aftermarket tubular manifold kit that doesn't need a load more fabrication to support the turbo and wastegate(s).
Cheers Chris! Appreciate the offer up of help& advise :) a conclusion has been reached upon inspection today. The turbo blades where inspected& are fine. The manifold despite heat wrap is fine, along with the down pipe after removal& a good inspection of both. The only reason that could be found was... after the NA-T the car was mapped on a stock pump. which couldn't handle the increased stress after 16 years.so with the walbro fitted it was causing over fueling. And obviously the reason it was running rich& with the excess fuel it was bogging down& struggling to make power..... The car after Dr_Jekyll road shotgun watched the boost gauge make 0.48 & AFR start to go back up to 11.4 from 10. So options I now have are a fuel map or refit a more reliable stock pump.
Quick question, I always assumed the heat wrap was an to retaining heat in the manifold but also helped with a more steady cool down? I know extreme temperatures can cause cracking. But I would have thought the heat wrap might have saved the manifold etc from extreme temperature changes on switch off and start up? If this isn't the case do you think it would be better to remove the heat wrap? Or would it depend on what reasons you use the car? For instance track or daily drive.
Heat wrap is used to keep engine bay temps down and retain heat in the manifold to increase thermal efficiency.
Unless you live in the artic you wont experience extreme temp changes, the manifold should be designed to cope with expansion and contraction. Like Chris said bracing a manifold is the key thing.
Aah! Thought that was what you ment :) seen these before, but not on such a large manifold!? With these, is it a case of custom fabrication? Or do somebody like Titan do these for the 2jz? When I was fitting the mani& turbo to my engine I was wondering if it could hold all that weight... Thanks for all the info :)
Should be- is opportunity to save money lol! I'm sure I can find some parts and have a go :) quite lucky with the NA TB mounting points :)
What's your thoughts on swapping the walbro back to a stock (new?)fuel pump? Should I wait and get a fuel map in a few weeks? And if I went back to a stock pump would a new fuel filter help with a better flow to the injectors?
