vukelic Posted October 12, 2011 Share Posted October 12, 2011 I plan on getting my N/A turbo'd eventually. Hopefully soon. Would you recommend that i find a turbo kit for it? or Do a complete engine swap? My the entire car only has only 67,000 kms on it. Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 12, 2011 Share Posted October 12, 2011 I would advise you use the search button, i cannot count how many times it has been covered. Link to comment Share on other sites More sharing options...
vukelic Posted October 12, 2011 Author Share Posted October 12, 2011 Yeah, i did that, was just looking for more current opinions. Link to comment Share on other sites More sharing options...
Noz Posted October 12, 2011 Share Posted October 12, 2011 has been about 5 threads covering this topic past month. just go through the supra chat section, your find loads of information and questions answered on this fairly recently Link to comment Share on other sites More sharing options...
anton Posted October 12, 2011 Share Posted October 12, 2011 You can only roughly turbo your N A engine upto 350 bhp and t that amount it is stressing the engine in my opinion. Better to go with a complete engine swap mate so if anything does go wrong then you can fix it easily and with second hand parts Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 12, 2011 Share Posted October 12, 2011 You can only roughly turbo your N A engine upto 350 bhp and t that amount it is stressing the engine in my opinion. Better to go with a complete engine swap mate so if anything does go wrong then you can fix it easily and with second hand parts wrong . and wrong Link to comment Share on other sites More sharing options...
Graham1984 Posted October 12, 2011 Share Posted October 12, 2011 I did one of these threads a couple of days ago. I think it all depends on how much you have to spend as like you my engine has done under 50k miles so it seamed a shame to waste it but I figured that unless you are going to spend top notch money on a kit then maybe its best to get the TT swap or sell up and get a legit TT. I am going to do a TT conversion as with the kits like xs power you have to get a bit creative for some and fabricate the parts which to be honest doesn't sound highly reliable and after totally up all the stuff you need £1100 turbo kit then a few £££ for the ic pipes plus need to make brackets to mount the inter cooler a £300 ish greddy e-manage kit £300ish upgraded fuel injectors poss head gasket kit and then a poss remap as well made me decide that its best to do all TT swap prop 2k + and it saves a lot of hassle. All this is my opinion so good luck to you in how you go about your car but bear in mind that you will poss have to upgrade the clutch and poss the gearbox to a six speed unless your auto either way its a long road depending how much bhp you want. I am only aiming for between 320-400 bhp as my car will be a daily drive so don't need massive power plus keeping it in that region will save me having to change everything from stock as well. Good luck anyway Link to comment Share on other sites More sharing options...
vukelic Posted October 12, 2011 Author Share Posted October 12, 2011 wrong . and wrong Would you please explain, i'm listening to all advices and opinions, as I myself am new to the supra community. And not a real strong car background to boot either. Link to comment Share on other sites More sharing options...
vukelic Posted October 12, 2011 Author Share Posted October 12, 2011 and thank you graham! And my car is indeed standard. Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 12, 2011 Share Posted October 12, 2011 well firstly around 400 hp is achievable on stock compression dependant on your ecu/injectors and mapper . im confident ryan 2 could get 400 bhp on the stock engine using one of the syvecs systems . even without an expensive standalone we just got 380 bhp at 7psi on welshstelths car. at thid level of tuning with a pro map and the correct afr on boost it will not be strseeing the engine atall. the ge bottom end is also very strong ast the gte bottom end is . the are fundamentaly the same bar a few minor differences. i myslef have just built a 480 bhp na-t by lowering the compresstion. the reason a stock ge engine is limited on potential bhp is in no way strength related. it is because the engine is high compression thus limiting how much boost you can run before it pre dets . secondly replaceing gte parts cheaply...... lol Link to comment Share on other sites More sharing options...
anton Posted October 12, 2011 Share Posted October 12, 2011 I was on about that it will be cheaper going with the gte engine transplant as the price for all the turbo kits and all that will mount up to be around the same and the parts will less of quality than the second hand gte parts. What can you get out of a NA without any turbos added? Also what about the gear box on the NA, will it not blow at 400bhp? I thought standard gte auto box was only good for 500bhp. I can remember someone saying that the NA box is only good till 350bhp? Link to comment Share on other sites More sharing options...
suprasize Posted October 12, 2011 Share Posted October 12, 2011 Sell up and buy a tt =) jobs a good'n Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 12, 2011 Share Posted October 12, 2011 its the torque and driving type that hurts the boxes , the w58 can die at 350 for one band be fine at 450 for another . my current w58 has done a full sprint season with a load of trackdays inbetween and its still sweet as a nut. it took mee 3 years to make the other one wine . 400 ish will cost about the same eithwer way. 450+ will cost moe either way. na-t s a good way to go if your handy with the spanners and like to be involved with your car. also sounds awsome and delivers the power more agressively than the twins Link to comment Share on other sites More sharing options...
anton Posted October 12, 2011 Share Posted October 12, 2011 Thanx for that Whats acheivable out of a NA without any turbos? What would it cost to get it to 300bhp roughly? Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 12, 2011 Share Posted October 12, 2011 wopuldnt happen mate , it wopuld cost tens of thousands to make 300 na power from a 2jz. really not worth it for the cost. if you want a 300 bhp na supra fit the 1uzfe engine . if you want to make your na faster tune the chassis . shed weight , better suspension, brakes , good tyres ect. this will make the car feel quicker. hosepower is not the allways the final word in performance Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 12, 2011 Share Posted October 12, 2011 Perfect answer above. Only so much can be achieved in NA form. The 4.0 v8 1uzfe is an awesome swap, a 2.5 T 1jzgte is better suited to the w58 apparently. Good luck what ever you do. Link to comment Share on other sites More sharing options...
vukelic Posted October 14, 2011 Author Share Posted October 14, 2011 Thanks for everyone who replied! very helpful and informative! i think i will probably sell it next year and buy a tt. only thing, supras can be hard to come by over here in Canada. Link to comment Share on other sites More sharing options...
