What material are the water elbow, main bypass pipe, cam covers.
Scott
As above really, looking to take some parts to a fabricator and just want to be 100% sure what all the parts are made of. I'm thinking cast aluminim for the most part but I just want to be 100% sure.
Water Elbow (connects to top rad hose)
Main Water Pipe (connects from pump to heater matrix)
Cam Covers (Self explanatory)
One little side note, I was looking at the water pump and I noticed it had a little pipe coming off the bottom. I don't remember this going anywhere. Is it a drain? Where does it drain from?
Thanks
Water elbow and cam covers Im 99% sure are cast ally, the water pipe that runs up the side of the block? I think thats also ally but might be steel, cant remember of the top of my head.
The pipe on the water pump is indeed a drain, a dry drain. If the bearing seal goes it will leak out of there
Ahh that explains it. I couldn't think of a reason for the drain lol.
You mean the one with two rubber O rings on it? I am 90% sure it's also made of aluminium alloy. I can have a look at an engine in build on Sunday, and confirm for you Scott.
Not sure if it has O-Rings, it's the one that connects to the water pump and feeds round behind the head. It branches off to feed the turbos, into the matrix and round the other side of the head to feed the TB & ICV (the one that stops it from freezing) before going through the stock oil cooler and back into the block.
I've taken away the oil cooler, my turbo is oil cooled and I'm not bothering with anti-freezing the TB & ICV so I'm just going to chop everything off other than the matrix feed and weld it all up :)
Take a magnet to it, it may be stainless but I thinks it's mild. If it's stainless it won't be magnetic. I seem to recall them rusting though.
Yeah I'll double check it. I didn't notice any corrosion on mine but I didn't really pay much attention to it.
Thanks again :)
