farmer Posted May 21, 2011 Share Posted May 21, 2011 as in the title, i have aquired a formula power amalgam filled inline octane booster, wich reports to enhance / boost fuel quality. ie 95 upto 100 octane. do these things work and are they safe to use. Link to comment Share on other sites More sharing options...
Suprab1 Posted May 21, 2011 Share Posted May 21, 2011 Are these the pipe things that go on the fuel pipe? I have seen evos ect with these but afaik they are only suited for upto a 2 litre. They are also suppose to last about 250k miles/km but i'd look into them alot more before i would put one on my car. Could you not just use Vpower ect? Link to comment Share on other sites More sharing options...
farmer Posted May 21, 2011 Author Share Posted May 21, 2011 v powers good but the nearest is 80 miles to the east and 40 ish north, they come for differing engine sizes but theres a lot of contradiction in peoples opinions. local fuel suppliers have not got a good reliable reputation except morrison but they dot have a premium pump. Link to comment Share on other sites More sharing options...
sideexitsupra Posted May 21, 2011 Share Posted May 21, 2011 Can you not get Tesco Momentum 99Ron? Thought most tescos were selling that now? Of course I quite understand if you do not want to put Supermarket fuel in your car. Link to comment Share on other sites More sharing options...
sideexitsupra Posted May 21, 2011 Share Posted May 21, 2011 http://www.tesco.com/storeLocator/momentum99.asp Use this link to find one near you Link to comment Share on other sites More sharing options...
farmer Posted May 21, 2011 Author Share Posted May 21, 2011 yeah thanks but the nearest tesco fuel is 60 + miles and i usually when i'm heading south judge it so i can fill there and refill on the return. could do with some support or advice on the use of one of these, the idea and theory sounds ok but ! Link to comment Share on other sites More sharing options...
Wez Posted May 21, 2011 Share Posted May 21, 2011 http://www.mhtextiles.co.uk/scripts/prodView.asp?idproduct=363 Link to comment Share on other sites More sharing options...
farmer Posted May 21, 2011 Author Share Posted May 21, 2011 well on paper they appear to have an advantage and no disadvantages or risks, so has any body got one of these fitted and do they work ? Link to comment Share on other sites More sharing options...
Paul Posted May 21, 2011 Share Posted May 21, 2011 I've got some snake oil if you're interested? Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2011 Share Posted May 21, 2011 They don't work, they can't work, and they are pure, unadulterated rubbish. If they DID work don't you think every engine maker would be using them on production cars to up the CR and get better emissions and performance? You have more chance of upping the octane by peeing in the tank than with those things. Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 21, 2011 Share Posted May 21, 2011 THE one and ONLY affect I can see this having on your fuel is reducing it's flow!! I've seen other versions before where you drop them into your fuel tank. As far as I can see, these are just well marketed pap!! As Chris said, if they really were magic, why are they not fitted to all high performance cars as standard? I think if I were you I'd steer clear. Link to comment Share on other sites More sharing options...
farmer Posted May 21, 2011 Author Share Posted May 21, 2011 ok. back to peeing into the tank then. but not in the pub carpark this time. Link to comment Share on other sites More sharing options...
Suprab1 Posted May 21, 2011 Share Posted May 21, 2011 I got chatting the lad in the shop who sells them & he told me he wouldn't put one is his s15, so that tells you they are just dung. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 21, 2011 Share Posted May 21, 2011 (edited) so that tells you they are just dung. Is that colloquialism meant to make "farmer" feel at home? Edited May 21, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Suprab1 Posted May 21, 2011 Share Posted May 21, 2011 Is colloquialism meant to make "farmer" feel at home? Ah Chris i don't understand them big words Link to comment Share on other sites More sharing options...
Swampy442 Posted May 21, 2011 Share Posted May 21, 2011 File it under bollox, throw it in the bin, have a word with yourself and crack on. Link to comment Share on other sites More sharing options...
