DodgyRog Posted April 9, 2011 Share Posted April 9, 2011 I have started refurbing my Work alloys and used Hammerite. I sprayed one of them a couple of weekends ago and went to move the wheel out of the Conservatory and I have left a slight finger print in the paint I find this really odd, surely they would be dry after 2 weeks, you can push your finger nail in quite easy Could it be due to the Nitromors I used to strip the wheels, I gave them a wash afterwards, but maybe it was not enough I didn't use a primer, but thought you didn't need to with Hammerite, thats why I used it and the fact it's supposed to dry so hard !? Anyway any help with this would be grateful received as I have one Black wheel and want to push on with the other 3 Cheers Rog Link to comment Share on other sites More sharing options...
ronttuk Posted April 9, 2011 Share Posted April 9, 2011 i had this with hammerite once i think i put it on to thick and it wasnt warm enough it took ages to harden Link to comment Share on other sites More sharing options...
scotty71 Posted April 9, 2011 Share Posted April 9, 2011 ask evinX he is our resident Hammerite king I think its the properties in the paint (rust inhibitors etc) Link to comment Share on other sites More sharing options...
DodgyRog Posted April 9, 2011 Author Share Posted April 9, 2011 i had this with hammerite once i think i put it on to thick and it wasnt warm enough it took ages to harden That would make sense in this case as well Since I did this one, I have found out that the best way to spray Hammerite is in thin dusting layers, but according to the side of the can it should only be left 15-20 mins between coats. Does this give a good result or should I be looking to leave the paint to dry properly between coats Link to comment Share on other sites More sharing options...
DodgyRog Posted April 9, 2011 Author Share Posted April 9, 2011 ask evinX he is our resident Hammerite king I think its the properties in the paint (rust inhibitors etc) I am sure he will see Hammerite in the title thread and cream himself:innocent: I take it the paint will go hard eventually then or should I restrip the wheel I have done and start again Link to comment Share on other sites More sharing options...
jazz1 Posted April 9, 2011 Share Posted April 9, 2011 Leave it out in this sun I'm sure it will get hard. Link to comment Share on other sites More sharing options...
Dnk Posted April 9, 2011 Share Posted April 9, 2011 Leave it out in this sun I'm sure it will get hard. and get lots of flies stuck to it Link to comment Share on other sites More sharing options...
DodgyRog Posted April 9, 2011 Author Share Posted April 9, 2011 Leave it out in this sun I'm sure it will get hard. I am not into all that Jazz;) It's in the conseratory so getting plenty of heat in there, but it's quite breezy out today, so maybe I will put it outside during the day Link to comment Share on other sites More sharing options...
scotty71 Posted April 9, 2011 Share Posted April 9, 2011 and get lots of flies stuck to it lol Link to comment Share on other sites More sharing options...
snake Posted April 9, 2011 Share Posted April 9, 2011 if you paint with hammerite you have to recoat within a set time period,i would imagine the spray has a similar spec, HI ROG Link to comment Share on other sites More sharing options...
SupraHuman Posted April 9, 2011 Share Posted April 9, 2011 Use a hot air gun and bake it for a while. Link to comment Share on other sites More sharing options...
