Why would Hammmerite Paint not go rock hard
DodgyRog
I have started refurbing my Work alloys and used Hammerite. I sprayed one of them a couple of weekends ago and went to move the wheel out of the Conservatory and I have left a slight finger print in the paint
I find this really odd, surely they would be dry after 2 weeks, you can push your finger nail in quite easy
Could it be due to the Nitromors I used to strip the wheels, I gave them a wash afterwards, but maybe it was not enough
I didn't use a primer, but thought you didn't need to with Hammerite, thats why I used it and the fact it's supposed to dry so hard !?
Anyway any help with this would be grateful received as I have one Black wheel and want to push on with the other 3
Cheers Rog
i had this with hammerite once i think i put it on to thick and it wasnt warm enough it took ages to harden
That would make sense in this case as well
Since I did this one, I have found out that the best way to spray Hammerite is in thin dusting layers, but according to the side of the can it should only be left 15-20 mins between coats. Does this give a good result or should I be looking to leave the paint to dry properly between coats
ask evinX :D
he is our resident Hammerite king :)
I think its the properties in the paint (rust inhibitors etc)
I am sure he will see Hammerite in the title thread and cream himself:innocent:
I take it the paint will go hard eventually then or should I restrip the wheel I have done and start again
Leave it out in this sun I'm sure it will get hard.
I am not into all that Jazz;)
It's in the conseratory so getting plenty of heat in there, but it's quite breezy out today, so maybe I will put it outside during the day
